Help Please
Posted 30/06/2009 - 20:56
if its the same as my k20d you have to enable the arpeture ring in the settings menu.
Lil Andy
K20D, PENTAX DA 18-55, TAMRON DI 70-300, PENTAX SMC-K 135 f2.5
www.ajohnson-photography.co.uk
Posted 30/06/2009 - 21:44
Normally you set the lens to the "A" position and adjust the aperture with the rear e-dial on the camera
(Trying to adjust the aperture ring on the lens is far less convenient as you have to perform "stop-down metering". Just use the "A" position!)
Posted 30/06/2009 - 21:58
Thanks for info. Lens has no "A" on it, this may well account for the display just blinking in aperture display. I take it that this lens is not compatable with camera.
Posted 30/06/2009 - 22:04
Nope thats when u gota use the arpeture dial and enable it in the settings :winklike I said if its the same as k20d)
Lil Andy
Posted 30/06/2009 - 23:54
toyman,
The lens will work fine on that camera. You just have to change one setting in the custom setup menu.
Posted 01/07/2009 - 00:54
I have this lens and have never had any problems with adjusting the aperture and have used it on my *istD, K10 and K20. No problems whatsoever. Great lens, I keep it as a spare as my wife uses it now and again.Thanks for info. Lens has no "A" on it, this may well account for the display just blinking in aperture display. I take it that this lens is not compatable with camera.
Paul
Yorkshire
