Help organising my images
I still use folders based on the date in the following format: 70417 would be the folder for today.
I am sure that there are as many sorting methods as there are Pentax users
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
Also when I first transfer the images from the card reader I have a folder structure along the lines of My Pictures > Year > Month > Topic or Location
I also have Elements and use the organiser there too for finding things...
The main thing is to pick folder titles that you will recognise and tell you what the contents are - it can be as complex or simple as you make it...
Will
My Flickr
When moving files to the PC I rename the folder on the card first then copy to my RAW folder, my naming convention is "2007-04-17 K10D", this makes windows sort in cronological order and differentiate folders from my old istD.
Brian.
Keith
K3 III, DA* 16-50, HD DA 16-85, DA* 50-135, DA* 300, HD 55-300 PLM, HD 1.4x, AF360
If you're using PS then you should also be able to install (or have installed) Adobe Bridge. This can sort, filter, apply tags etc...
Otherwise Ulead Photo Explorer is good for $30
My Flickr
Then everything is simply imported into Extensis Portfolio, and this then creates previews and all images are in separate databases. So if I go to a zoo for example, then the result will be 1 CD/DVD and one Extensis database. The database will contain, the date of the shoot, location, and all the images will have their original names with descriptions, exif etc added.
The originals remain on the CD/DVD.
I used to keep all images on the Hard drive, but that gets a pain, as the number of images rises!
I am investigating Silkypix Studio for my graphic application, but for storage as mentioned above, I burn all images to CD/DVD, and import to Portfolio.
West Mids UK
I want to organise my images into thumbnails in PS can this be done as I am fed up of having hudreds of images all over my hard drive I need to get them in some sort of order. Any suggestions
Pete
