Help me with a weird problem
NaimKhan
Posted 17/04/2011 - 10:10 Link
Come on guys give me some credit. I have been taking photographs for long enough to know when there is camera shake. The picture you see is exactly what I saw in the viewfinder. When I started the thread I hadn't evrn taken a photo - I had been talking about what I saw in the viewfinder.
Naim
testdasi
Posted 17/04/2011 - 10:39 Link
Naim
I stick with my previous comment re low quality filter. What brand is yours?
I'm guessing because the 300mm has very small field of view, it uses a very small section of the filter. So whatever imperfection is magnified.
In any case, try using a stable surface (instead of hand-held) to take out any possible effect of camera shake.
[IMG]http://i292.photobucket.com/albums/mm33/testdasi/Images/Pentax%20K-5/pk5sig.gif[/IMG]====================================
My Flickr
The Rotary Shutter
sterretje
Posted 17/04/2011 - 10:50 Link
NaimKhan wrote:
... When I first looked in the viewfinder I thought I had changed the diopter by accident.
I think that testdasi is right based on the above.
cintelli67
Posted 17/04/2011 - 11:16 - Helpful Comment Link
I suppose the problem is the Filter. For some reason the AF on the camera gets in conflict with the circular lines of the POLA.
The solutions are two:
1) Test the lens with a linear Pola.
2) Lock the focus with AF-Lock button and then insert the POLA. If it is still blurry the best use you can do with your CPL is transform it in a UFO and shot it . Then sell the picture to some Sci-fi magazine and take the money to buy a better one.
But it is still strange that the CPL on the other lenses works , but on the 300 star not. Then you lose only one stop while using the CPL. I have a Cokin Circular and B+W linear and in both of them I loose two stops.
Strange filter
Ciao
Alberto
Mannesty
Posted 17/04/2011 - 11:27 Link
Camera shake, no question. At 1/60th you needed to use a tripod and turn off shake reduction with that lens.
gartmore
Posted 17/04/2011 - 11:56 Link
Algernon wrote:
Probably the 2 stops or so lost through the filter causing
camera shake.
Even the 2nd shot should be sharper it's a top lens.
Edit: Just noticed they are both 1/60th and the iSO was changed. You need at least 1/300th with a 300mm lens?
It still looks like camera shake.
Actually on APS-C it becomes more like 1/500th because of the field of view.
Algernon
Posted 17/04/2011 - 12:05 Link
gartmore wrote:
camera shake.
It depends on the user plus the SR helps. I'm happy with 1/200th and I think most would manage 1/300th. It would be very rare to need 1/500th with SR
NaimKhan
Posted 17/04/2011 - 19:57 Link
OK, for are you sceptics here are 2 more shots that I have taken with a tripod + 2 seconds delay timer. You can see that the problem remains as I mentioned previously.
More news further down
This one with the CPL:
[IMG]http://i376.photobucket.com/albums/oo209/Naim-Khan/NAIM9322.jpg[/IMG]
This one without:
[IMG]http://i376.photobucket.com/albums/oo209/Naim-Khan/NAIM9321.jpg[/IMG]
The news is that I put another CPL in front of the lens - it is not the correct size so couldn't screw it on, but what I did notice was that the view in the viewfinder was absolutely fine. So in summary, looks like I have got myself a dud CPL . I bought it abroad so can't return it either.
greynolds999
Posted 17/04/2011 - 21:22 Link
As has been said many times, this is the filter. It is faulty and should be binned or returned.
Algernon
Posted 17/04/2011 - 21:35 Link
The polarizers creating more than one image, which is why it looks like shake. It could even be letting un-polarized light through and it's that causing the blur. You can see it best on the twigs on the right the extra images run right to left.
hefty1
Posted 17/04/2011 - 22:24 Link
Polarising filters are made up of a polarising foil sandwiched between glass plates. Sometimes these de-laminate which would likely cause the problems you're seeing. Nothing you can do to repair it unfortunately.
Joining the Q
