Help me choose
This topic has a poll - login to enter
Posted 06/07/2011 - 17:52
This is right in the corner of the frame? My 18-55 goes mushy in in the extreme corners... at 18mm anyway.
Example: http://i786.photobucket.com/albums/yy148/willdb_photo/1645%20vs%201855/18-55-l.jpg
16-45mm comparison: http://i786.photobucket.com/albums/yy148/willdb_photo/1645%20vs%201855/16-45-l.jpg
Posted 06/07/2011 - 18:07
johnriley wrote:
You're looking at two very small images there. When we get to A3 exhibition prints we can expect to notice which is which!
These are 100% 1:1 crops and each pic is about 370 pixels wide. The K-5 frame is 4928 pixels wide so each pic is 4928/370 say 1/13th of the frame. On my monitor (19") each pic is 110mm wide so the full print would be 110mm x 13 = 1.460 meters wide. A3 is 420mm wide so what I'm looking at on the monitor is roughly 3 1/2 times as wide as A3 You're looking at two very small images there. When we get to A3 exhibition prints we can expect to notice which is which!
You wouldn't see any difference in A3 prints
Tozza27 has just posted a shot of a seagull in the Entries for fortnightly competition #71 WILDLIFE taken with the Kit Lens and it shows what it's like for bird shots.
Posted 06/07/2011 - 18:15
Will: .... very wide angle lenses always look awful at 1:1. It's well known that the 16-45mm is better below 24mm than the 18-55m after that they are similar. You can see the PF on the 16-45 though. The 18-55mm doesn't look in focus ( look at the downspout )
John: You must have a very good 35 and a bad Mk2 Kit lens
Posted 06/07/2011 - 18:29
You still haven't told us which 35mm lens you're talking about?
Posted 06/07/2011 - 18:32
Nope, kit lens performs as expected, better than the MkI I had. The FA-35/2 reaches it's outstanding optimum resolution by f/4, so does the FA-50/1.4. I believe the FA-31 Ltd and FA-43 Ltd do as well, but I don't own either unfortunately. This is where fast primes really come into their own, when they can give away 2 stops and still match the zoomJohn: You must have a very good 35 and a bad Mk2 Kit lens
John
Posted 06/07/2011 - 18:49
This one:You still haven't told us which 35mm lens you're talking about?
http://www.flickriver.com/search/35mm+flektogon/
which as you can see is an Excellent lens with a lot of
character and gorgeous bokeh. nice colours as well
One sold for £190 the other night on ebay.... not even
mint
Posted 06/07/2011 - 18:52
Algernon wrote:
This one:
Highly overated IMHO.This one:
John
Posted 06/07/2011 - 18:55
Thank you. The 35mm Flektogon was a relatively inexpensive East German lens, designed for film and never having much of a reputation in its day.
In some circles it has gained a reputation, but in my view it is not a deserved one. I would certainly not pay £190 for one and the pictures linked to don't inspire me to desire one.
Clearly we are looking at very different things in a lens, so we shall have to agree to differ.
Posted 06/07/2011 - 19:34
What's most interesting here is the extraordinary quality of the Pentax kit lens, esentially a lens which was "given away" with various cameras.
I have no axe to grind on this one: I don't own any expensive or exotic limited lenses nor ever will.
I must be very lucky with my version of the mk1, although I nearly always use it at moderate apertures albeit throughout the full zoom range.
I bought it with a K100 and fully expected to see its limitations exposed when mounted on my "new" K10 with its more densely populated sensor but, if anything, the results are even more pleasing to my untutored eye.
I've flirted with the idea of replacing it with one of the above mentioned lenses (well, it's nice to dream) but every review one reads seems to contradict another or to reveal some deficiency or other. So I haven't felt the need to part with in excess of a week's wages.
I do use lots of my cheap pre-digital, manual focus primes, not because the results are superior, but because it's fun to do so.
Good luck with whichever lens you decide to buy; you'll always have your kit lens as a reliable back-up.
Best wishes,
Robert Adams
Ernst Hass
Robert Adams
Ernst Hass
Posted 06/07/2011 - 19:45
johnriley wrote:
The distance to the subjects at the edge of the frame might be a factor. If they fall outside the depth of field then sharpness would suffer.
Coming in a bit late on this one, but just to pick up John's point...The distance to the subjects at the edge of the frame might be a factor. If they fall outside the depth of field then sharpness would suffer.
I thought the whole point of a rectilinear lens was that the focus distance refers to the perpendicular distance from the film plane, to a plane (containing the subject), which is parallel to the film plane.
In other words, the focus distance of something at the edge of the field is the same as the focus distance at the centre of the field.
I've tried to illustrate it with this diagram:
[IMG]http://i162.photobucket.com/albums/t244/chris5gd/Technical/FocusDistance.jpg[/IMG]
The fact that the slant distance, ie the distance from the camera to the object at the edge of the frame, is greater than the focus distance, is completely irrelevant - or should be if the optics are perfect.
So if an object is within the DOF at the centre, it should be within it at the edge - and if I understand it right, edge softness is when the optical quality means that reality doesn't match the theory.
Posted 06/07/2011 - 20:00
Algernon wrote:
It's well known that the 16-45mm is better below 24mm than the 18-55m after that they are similar. You can see the PF on the 16-45 though. The 18-55mm doesn't look in focus ( look at the downspout ):
Hmmm... the shots were at f8 and live-view focussed on the same spot. Could it a be curved-field effect? But anyway, I have noticed in general use that the kit lens can be ropey in certain challenging conditions where the 16-45 can be relied upon at pretty much any setting, apart from that CA which is banished in a second in PP. There is CA on the 18-55 shot too, more of a blurry cyan/red type.It's well known that the 16-45mm is better below 24mm than the 18-55m after that they are similar. You can see the PF on the 16-45 though. The 18-55mm doesn't look in focus ( look at the downspout ):
I never had any complaints with my mk1 Andrew, but I think that may have had to do with the smaller 6MP sensor of my istDL, and that I hadn't yet succumbed to the peculiarly futile and joy-draining pastime of pixel-peeping back then What's most interesting here is the extraordinary quality of the Pentax kit lens, esentially a lens which was "given away" with various cameras.
I think the kit lens is good, but I think people are overstating the point when they say it's 'excellent' etc. It's certainly good enough that a great photographer can make it shine, as you certainly do.
Posted 06/07/2011 - 20:03
Having seen your work Andrew, it's obvious that your Mk1 is one of the good copies, similar to the one I had. There's no point in buying a Mk 2.. you won't see any difference.... I couldn't
Posted 06/07/2011 - 20:10
Chris I think you have it more or less in a nutshell
A real torture test for any lens is to photograph a large lattice railway bridge square off from the side and then see if the rivets at the edges are as sharp as the ones in the middle and if both edges are the same.
Tougher still turn the camera so the bridge is on the diagonal and see if the centre and corners are sharp.
24 years
Tyldesley,
Manchester
