HELP I've lost my SR
vic cross
Posted 11/10/2009 - 10:43 Link
Help I've lost my SR in all but USER & MOVIE. I go to capture 4 to set it but Shake Reduction & Input Focal Length are both greyed out. You have to go to SR to turn it on but because it is greyed out I can't get in to it. It is OK in user & movie but turned off in all other progs. There is no answer in the trouble shooting section either. What buttons have I wrongly pressed? HELP! CHEERS Vic.
PS It is a K7 Vic.
PPS I just checked and SR is still on the Green Mode.
Edited by vic cross: 11/10/2009 - 10:52
matwhittington
Posted 11/10/2009 - 10:54 Link
Have you adjusted the drive mode at all? I notice that whenever I switch to shooting with a remote control, the shake reduction is disabled (presumably on the premise that the camera will be attached to a tripod...) - similarly when the camera is in self-timer mode, the SR is disabled (presumably for the same reason). Not sure if that helps - am sure others will understand the K-7 menus better than I do (yet)...
Mat
Mat W
My Flickr: link
aminstar
Posted 11/10/2009 - 10:57 Link
Hi Vic
Like Mat mentioned, if the K7 is anything similar to the K20D then most probably you have the camera set up for self timer or remote shooting.
I would check that first
Anvh
Posted 11/10/2009 - 11:00 Link
Maybe you have changed it to off in the menu???
Stefan
K10D, K5
AF-540FGZ
vic cross
Posted 11/10/2009 - 11:01 Link
Thanks Mat. I had just been playing with the Drive Mode and had left it on Mirror Up. My short term memory is shot. I think there must be more computing power in this camera than they had when they went to the moon. Once again thanks. CHEERS Vic.
PS and thanks to all who replied. CHEERS Vic.
Edited by vic cross: 11/10/2009 - 11:03
Mongoose
Posted 12/10/2009 - 13:13 Link
Alarmingly for those brave men who went to the moon, that is almost certainly true.
but it does help
Anvh
Posted 12/10/2009 - 13:30 Link
Even today's simple calculators have more.
Stefan
K10D, K5
AF-540FGZ
Mongoose
Posted 12/10/2009 - 14:01 Link
Amazing what was achieved with so little isn't it?
It has come to my attention recently that we are living in the future!
but it does help
leytono
Posted 12/10/2009 - 15:09 Link
Or did they?
Anvh
Posted 12/10/2009 - 15:17 Link
Indeed but the electronics was highly specialize and only could do one thing and that's it so you don't need a lot of power if it's highly optimized.
leytono wrote:
Or did they?
If they didn't the USSR would have done the best they could too prove that don't you think?
Stefan
K10D, K5
AF-540FGZ
Anvh
Posted 12/10/2009 - 15:44 Link
cardiff_gareth wrote:
[Houston - we have a problem springs to mind
Cancel that ground control - mirror lock up was activated !
link that could have been the problem there
and another one, manually operate this one link
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 12/10/2009 - 15:46
