Help A90 error on my OptioS
Posted 15/02/2007 - 09:51
Hi L66TTY, and welcome to the forums..
According to the error list..
https://www.pentaxuser.com/faq/pentaxerrorcodes.html
any A error is a problem with the main printed curcuit board, and needs to go back to Pentax to be fixed.
If it's still under waranty, and if it's the UK, that can be in effect up to 6 years, certainly two, then take it back to the shop and ask for it to be repaired for free. It's the shop's responsibility to sell you an item that's fit for the purpose it was intended for.
I'm sure someone will explain that better than I just did.
Liam
Liam
Liam
Posted 15/02/2007 - 14:01
And let us know how you get on
Graham
Graham
Keep up the good work
Graham
I'll think of something someday.
Graham
Posted 15/02/2007 - 23:03
It was bought in Kuwait when I return I will take it to the shop there and see if they can help if not will send it off to be repaired.
Oh that is annoying!
Posted 16/02/2007 - 17:30
I bought my *ist DS in the USA, but Pentax in Slough repaired it (still under warranty) without a problem.
Many thanks in advance!
