Help a numpty
SteveEveritt
Posted 06/12/2011 - 17:04 Link
I have only recently ever used a proper flash and picked up one of the Sigma EF-610 DG ST when SRS were doing a deal a couple of weeks back. My problem... When it is mounted on the K-7 with the Sigma 70-200 attached and the camera is set to continuous shooting the flash fires with every shot, but when I mount my DA* 16-50 it flashes every now and then, certainly not for every shot. Any ideas?
col55555ine
Posted 06/12/2011 - 17:23 Link
maybe it's the siggies talking to each other
k-5 IIs, Pentax 60-250, 17-70, 100macro WR, 50mm F2,
AF50 F1.4, Siggy 10-20, Siggy 100-300 F4, ..Pentax Af 160 ring flash
Tyr
Posted 06/12/2011 - 18:34 Link
Could be to do with the power output required for different focal lengths. If you are shooting wide you need more power as it has less range. This increases recycle times and you only get one flash every 3-5 seconds rather than 3-5 per second.
SteveEveritt
Posted 06/12/2011 - 18:41 Link
Thanks Dan, that seems to make sense.
sterretje
Posted 07/12/2011 - 06:25 Link
If Dan is right, you should not see much difference between 50mm and 70mm.
