Help?
Posted 13/03/2005 - 20:01
I am assuming from what you say that you put the lens into the converter off the camera body. With some accessories it is better to mount the converter on the body, then the lens on the converter. I'm just a bit hesitant to suggest you do that now that it is stuck, at least without being able to see what is happening.
It's probably safer to take it somewhere it can be examined properly - a local repairer if you have one?
Posted 13/03/2005 - 21:02
i'll take it to jessops, and see if they can help, if not its up to london
21 years
they're both pk mount, it will swivel, as if to come out, but it wont.
