Help - lens question for stereo print experiment.
willyolly
Posted 09/11/2013 - 11:46 Link
After seeing Brian May's (of Queen fame) stereo photos at http://www.londonstereo.com/index.html and seeing that I can buy a Owl print stereo viewer from them; I dug out my old Russian slide stereo unit to try on my K5. The unit was designed to be used for 35mm slides with a 58mm lens. For digital prints I need either a 35 or 40mm lens that can be manually focused AND the lens front element must not rotate when focusing. Could any of you guys tell me which KA or DA lenses in 35 & 40mm have these two qualities. Thanks.
gartmore
Posted 09/11/2013 - 12:56 Link
I've tried the DA 35mm f2.4 and it certainly works using the Pentax Stereo Adapter, the front ring doesn't rotate and both are 49mm filter thread. It didn't work as well as I had hoped in terms of IQ. It was easy to print 6x4 prints. It's a great lens at a bargain price, welcome to the forum.
Edited by gartmore: 09/11/2013 - 12:59
Algernon
Posted 09/11/2013 - 14:05 Link
You can also take stereo shots of static subjects by using
a focus rack turned through 90deg and moving the camera by
the distance between the lenses between shots.
