Help - Cheap pistol grip
jeallen01
Posted 27/05/2013 - 10:11 Link
I've just bought one of these
http://www.amazon.co.uk/gp/product/B00ABIV9VA/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
It works well but for one BIG problem which does not show on the main image, but in the other the other one (fitted to a Canon G12), you can just see that there is a button (the "LOCK" button) just above the thumb of the hand holding the grip - and that can easily get depressed and locked-in when you are squeezing the trigger to fire the shutter.
Net result, with the K-5 in "machine gun" mode as I use it at airshows, you suddenly realise that the camera has taken another 20 shots (mainly of anything but aircraft!) before you can react and manually push the LOCK button again to release it! .
So does anyone know if you can release the two screws at the top rear of the grip (not shown on the images) and get inside and disable the LOCK button (which I will never need)?
Thanks in advance.
John.
PS - at Duxford yesterday, far too many big CANONS although I think I might have seen one Canon owner who was also carrying something like a K-5!
smc
Posted 27/05/2013 - 11:07 Link
how about a small drill hole and safety pin through the button, like a fire extinguisher. Removable if you do need to use the lock button.
Patty
Posted 27/05/2013 - 11:25 Link
If you cant get inside, try borrowing an angle grinder and grind the protrusion off. ( I take it that its working similar to an electric drill switchgear)
Pat
jeallen01
Posted 27/05/2013 - 11:42 Link
Thx - but don't think that's possible because of the shape of the handle with the button on the longer side of it
jeallen01
Posted 27/05/2013 - 11:47 Link
Pat
I'll have to try something like that - at the moment I am rather more interested in as to whether it is possible to get the handle open without damaging it too much.
John
jeallen01
Posted 12/06/2013 - 18:00 Link
jeallen01 wrote:
Pat
John
In the end I decided not to risk trying to take it apart - so I just cut off the protrubing part of the switch button with a junior hacksaw and then covered the remaining end of the button with some insulating tape. That looks like it should work, but we shall see :
jeallen01
Posted 15/06/2013 - 14:52 Link
jeallen01 wrote:
jeallen01 wrote:
Pat
John
Have now tried the tape-secured Lock switch on the K-5 indoors, and it seems to work fine with no tendency to continue firing the shutter after I release the trigger!
