Heeeeeellllllllllllllllllp
techno-terminator
Posted 03/03/2010 - 15:09 Link
guys I've hit the brick wall again
Trying to do this Macro thing and not coping at all well
Can't shoot it manually on the K-x - don't know how to set it up there at all - have tried but there's too many things for me to have to set - I don't know where to start.
so went back to the K-x and put it to macro - very difficult to get it focused and it insisted on using flash
NOW how can I manage this - instructions in very very simple terms please .
These are what I did get - and I know they won't do
[IMG]http://i8.photobucket.com/albums/a41/Anhelyna/IMGP0626.jpg[/IMG]
[IMG]http://i8.photobucket.com/albums/a41/Anhelyna/IMGP0625.jpg[/IMG]
I would like to get the whisk through it's 'working end ' and crop it at the handle
I feel defeat staring me in the face again Part of it is this insistence on abstract - and that's just not me - my mind doesn't work like his
let the education continue
Father Ted
Posted 03/03/2010 - 15:18 Link
Macro always gives a very short DoF.
I think if you want to get the whole whisk you'd be very lucky.
I've only tried this sort of thing a few times, but I'm always amazed at how small the DoF actually is.
Try in manual, on a tripod, with small aperture and long exposure. Oh, and focus 1/3 up the whisk.
That might work
nass
Posted 03/03/2010 - 15:27 Link
Your assignment is an abstract macro?
Mike-P
What lens are you using?
techno-terminator
Posted 03/03/2010 - 15:32 Link
That might work
I don't know HOW to use Manual - I'm not ready for that yet - still only using Av and Tv and sometimes struggling with those
I don't want the whole whisk - just the ballon end - and right at the end too
thoughton
Posted 03/03/2010 - 15:34 Link
Also, you've said that these shots won't do. Why not? Until we know what you are supposed to accomplish any advice is a bit hit and miss.
if it's simply a case that the first shot isn't close enough, then Mike's question is very relevant and should be answered. You might simply not have the right equipment.
Tim
Edited by thoughton: 03/03/2010 - 15:36
Mannesty
Posted 03/03/2010 - 15:37 Link
First, what does the term macro mean to you?
Macrophotography generally requires at least 1:1 magnification or greater. A life size or bigger image in other words.
To achieve this with only a standard lens is not possible. You may be able to get very close but you will not achieve true macro.
There are several ways to achieve a 1:1 or greater magnification.
1: Use a true macro lens at its minimum focus distance. All the major manufacturers produce them but a manual focus 90mm or so will be ideal. Auto focus can be a hindrance when doing macro shots.
2: Fit extension tubes between your camera and lens. The middle of a toilet roll can be used for a DIY solution. Ideally the lens needs to be something like a 50mm prime.
3: Fit a bellows unit (adjustable extension tube) between your camera and lens.
4: Reverse mount a 50, 35, or 28mm lens to your camera. For this you will need an adapter or devise a DIY method to do it.
5: Stack two lenses together. With a 200mm lens fixed to the camera and a 50mm lens reverse mounted to the front of it you will get approx. 4:1 magnification. Again, you'll need an adapter (stacking ring) having the right filter thread sizes for the two lenses used.
There may be other ways, but I don't know of any.
Lots of light is generally needed to allow a smaller aperture to combat the very narrow depth of field that is typical in macro work. That's probably why your camera is insisting on its use.
Hope that helps.
Edited by Mannesty: 03/03/2010 - 15:41
Father Ted
Posted 03/03/2010 - 15:41 Link
Oops, my misunderstanding
techno-terminator
Posted 03/03/2010 - 15:43 Link
Nass - he just said Macro , something from the house but all the examples he showed were very definitely abstract - loose wire wrapped round something solid , things interlocking etc etc
Mike-P was using the 18-55 - at 55 but it wasn't happy focusing . Had tried setting the shot up in Av but could not get the hexagon steady no matter how I adjusted my aperture .
I've just had another go with the Optio [ fabulous wee camera - lots to get used to on it ] and finally got these
[IMG]http://i8.photobucket.com/albums/a41/Anhelyna/IMGP0025.jpg[/IMG]
[IMG]http://i8.photobucket.com/albums/a41/Anhelyna/IMGP0024.jpg[/IMG]
[IMG]http://i8.photobucket.com/albums/a41/Anhelyna/IMGP0023.jpg[/IMG]
Yes - would need to crop the last one [ that Optio lens is certainly wide angle ]
Mike-P
Posted 03/03/2010 - 15:50 Link
This close? (uncropped)
Im more worried about the state of our whisk now
[IMG]http://img.photobucket.com/albums/v188/Sockpuppetuk/_IGP3090.jpg[/IMG]
AV mode, F9 and use your onboard flash .. knock it down as low as it will go. You will have to crop a lot more as you are not using a macro lens.
Edited by Mike-P: 03/03/2010 - 15:53
techno-terminator
Posted 03/03/2010 - 15:57 Link
Mike-P - that's nearer , I think, to what I want
This task was just a last minute thought he had - after we had talked very vaguely on the subject of White Balance and ISO and his suggestion for them was to leave WB on auto and keep ISO low so we didn't get noise ,and then we 'played' with Photoshop and he wants to spend most of the time on that now , and I don't 'cos I need to learn so much more about this K-x and how to get good photos with it - I know I can on Auto - but I don't want to do that all the time or I might as well have stayed with a simple P&S which would not give me what I want.
nass
Posted 03/03/2010 - 15:58 Link
Whatever you did on your camera to get #2, that's the nearest thing to an in focus macro. Can you repeat and get the focus onto the front?
postedit: see Mike's example. 'nuff said.
Edited by nass: 03/03/2010 - 15:59
techno-terminator
Posted 03/03/2010 - 16:01 Link
I can try - it's the Optio on its macro setting
I was above it and looking down and possibly at a slight angle . I'll keep trying that one - thanks
nass
Posted 03/03/2010 - 16:15 Link
Nonononono - do what Mike says. If you can show the work on a PC use a crop as he suggested, it's a lot more Macro. Point being you need to make it bigger than life size and if that involves a crop at 1:1 on a PC screen so be it
Edited by nass: 03/03/2010 - 16:15
techno-terminator
Posted 03/03/2010 - 16:45 Link
OK - any better ? - not cropped as yet
[IMG]http://i8.photobucket.com/albums/a41/Anhelyna/IMGP0628.jpg[/IMG]
[IMG]http://i8.photobucket.com/albums/a41/Anhelyna/IMGP0629.jpg[/IMG]
This time the K-x was much happier. I've focused as far down as I can and was surprised that the flash didn't this time .
I have a meeting tonight - so can't do any more now till tomorrow - but thanks you have all once again , given me confidence that I'll get there .
