Gitzo Tripod
Posted 18/05/2017 - 16:27
Now sold so mods please archive
Thank you
Thank you
Cambridge
Centre column has been removed and replaced with genuine Gitzo Ground Level set link
Basically gives a very stable series 1 systematic type tripod with a height of approx.138cm/54.3in
A centre column can be purchased as a spare part, the tripod has all the parts required to accept a column should it be wanted (not necessary unless you are over six foot tall)
Other specifications
leg sections 4 weight 1.1kg / 2.5lbs
closed length 54.0cm / 21.3in
maximum height (with center column down) 138.0cm / 54.3in
load capacity 8.0kg / 17.6lbs
Folds down to 54cm which is within normal airline carry on limits, fits in my walk on case and easy enough to strap to a backpack, light too at just over 1kg
Only fault I can find is the hook at some stage has lost its little spring.
Price £185 includes tracked and insured postage within the UK
Thank you
Richard
