Gigapan Epic Pro
Posted 10/08/2021 - 08:21
Have you tried a wired remote that you know triggers K3 and K7?
Posted 10/08/2021 - 11:38
The only wired release I own is the Gigapan. I thought somebody else having a Gigapan could tell me if they had the same issue.
Posted 10/08/2021 - 20:01
On the other hand, my K-3 mk iii does work with my Manfrotto MVG 460 gimbal using a "home made" solution: I use a male to male 3.5 mm. x 1 meter stereo audio cable with a female 3.5 mm. to male 2.5 mm. reducer. Pulling the audio cable slightly out of the reducer allows me to use the camera button on the gimbal to control the K-3 mk iii shutter. Now, life looks a little brighter. It never worked with the original K-3.
Posted 11/08/2021 - 08:48
I'd compare the dimensions of the plugs - Gigapan Vs home made - as on the face of it the Gigapan plug isn't making good contact in the K3 III socket but the home made one is.
Posted 11/08/2021 - 14:16
The home made plug can't be used with the Gigapan. The Gigapan end of the cable is mini USB while the camera end is male 2.5 mm. stereo plug. My knowledge of electronic is insufficient to make a custom cable. But I think you nailed the problem. I'll order a new cable from Gigapan to see if it solves the problem.
North of Montreal,Quebec,
Canada
