Garden Portraits, Plus Explanations
Posted 26/05/2016 - 16:59
I forget to add one technical detail .... The flashes both had a 1/4 CTO gel ('Colour Temperature Orange' ) added to them, in order for me to be able to use a daylight white balance setting. The gels help to balance the flash and ambient colour temperature ...
Without the gels the flashes would produce a cooler, bluer look on the faces. My white balance setting was the daylight preset with a plus 3 orange fine tuning.
Posted 29/05/2016 - 04:11
Thanks Nigel, it`s always good to see these sort of tips and advice posted on here, keep up the good work.
Posted 29/05/2016 - 08:55
Looking good. With the first 2 of your better half looking at the shadows on the body as well as the face, it looks like when you've placed her into the scene she's slightly in line with the key light rather than the preferred 45° subject, camera, flash triangle set up. I don't think the hair light was powerful enough as the hair doesn't have that rim light the hair light should produce. I think that light would of been better diffused and placed low power nearly straight on to fill the shadows and then offer a better softer lighting over the face.
Nice technique though! I only have one HSS flash which I kept for just what you've done, must buy another! I've just invested in another Yongnuo 560VI, Bowens light adaptor with reflector, grid and sock so I'll be practising more outside portraits myself soon
Posted 29/05/2016 - 09:13
Thanks Don and Gareth I'm lucky that I really just enjoy messing around with the gear ... Flash stuff is fun, and if I get some decent results as well then that's the icing on the cake!
Some good points re placing the Gareth, thanks ... Unfortunately that day neither model was in much of a mood to be 'positioned' ... No doubt I could have cranked up the rim light, and I will try your idea as an alternative, cheers.
Posted 29/05/2016 - 10:05
Interesting stuff thanks guys.
I've said this before, wish i had willing models to practice with as outdoor flash is something I'd like to improve on, but the girls in our house are just too shy!
Posted 29/05/2016 - 11:16
Yes, unfortunately, without paid models it never really seems as easy as it does in the books! My best approach is to do as much of the prep work before (hence the doll), and make sure everything is firing ok and the power settings are right before you start 'bossing' any girls around
Gareth, if you don't have one then for HSS it's hard to beat the Cactus RF60 ... Only manual power control, but it's HSS sympathy mode plus ability to dial in an exact delay, means it can fit in nicely With a Pentax PTTL flash ...
In this scenario here the Pentax flash with the snoot on was working in P-TTL mode (that's a requirement for Pentax wireless HSS) and the Cactus was manual (because that's all it can do). The delay setting of 100ms means that the Cactus fires at the right time after the pre -flash from the on-camera Pentax flash (and that is set to 'wireless HS control' mode, meaning it does not contribute to the lighting, plus you can point the flash head directly at the slave optical sensors).
So an economical and reliable 2 slave HSS set-up could involve a Pentax flash as controller and 2Cactus RF60s as slaves. You do have the option worth a Pentax flash of switching in into 'Master' mode also and using it to provide light, perhaps as fill , so long as the trigger signal can still be seen by the slaves.
Surrey,
England
I use a 2-flash set-up for HSS, one Pentax AF-540FGZ and a Cactus RF60. Both are triggered optically using another on-camera Pentax AF-540FGZII (set to 'wireless control' mode). For more details on the technical side of all this please check out my demo thread over at PF .... link
The camera here is the K7 with SMC F35-70 f3.5-4.5
Here's the general scene, with a 'normal' ambient exposure ...... ISO 100, F5.6, 1/350th sec
With these settings in order to reduce the background brightness more I'm going to have to use shorter exposures because I don't want to use smaller apertures for these portraits .... So that puts me firmly into HSS territory for my flash working .....
Heres the set up with my 'Practice Doll' .... I always use a static doll or teddy to test the lighting and balance the exposures before my impatient models arrive on the scene ... (well, they're not being paid!) ...
The sun is off behind the subject position to the camera right, so I am using my lights on the subjects left side .... the main light is the softbox and the other light with powersnoot is for a kind of back rim effect to add a bit of depth around the hair and profile ....
You can see that I have angled the flash bodies towards the shooting position in order for the optical sensors to receive the control triggering signal. The distances here are around 4 metres to the farthest flash. The main softbox is about 1 metre from the subject. The head of the control flash on the camera is turned to point towards the slave flashes and the flash head zoom was set at 24mm coverage to ensure both flashes got a good signal.
Here's the test subject with only the rear rim light firing .... you can see the face mainly in shadow and the background darkened due to the shorter exposure time ....
ISO 100, F5.6, 1/500th Sec
And here's a few with the main flash as well, providing my chosen flash and ambient balance .... I aimed for a very soft effect with the softbox close to the subject and the light strongly directional to create contrast across the face ....
First a rather tired model ... (but she had a fairly good excuse ) ...
And lastly a rather grumpy model ... But she had NO excuse.
Hope you found it interesting ..... its a great way to get portraits at home and work around the difficulties of shade and sunlight. Please raise any questions or thoughts, that's what it's all about
