Garden Macros and Snakes
Posted 07/07/2019 - 22:56 - Helpful Comment
Woo hoo, what a set
Super balance of detail, colours and composition.
I tend to sacrifice all for detail, just cant help it 😂
So for me this set is great, how they can be shot.
No critique just well done. 👏👏👏
Posted 07/07/2019 - 23:02
derek897 wrote:
Woo hoo, what a set
Hi Derek, thank you for your comments! I always place composition as my highest priority, which might be why these images are as they are. My thought process is to get the composition right and try my hardest to get critical focus in the right place, but to get the compo right I never use any kind of camera support as it is too restrictive. This leads to a lack of sharpness (sometimes), but I think it's worth the sacrifice. I prefer the non-flash shots, but the flash does give leeway for a bit of camera shake. Everything is a compromise with macro, especially if you're doing it outside with live critters and no controlled conditions.Woo hoo, what a set
Posted 07/07/2019 - 23:05 - Helpful Comment
Such a strong set David, great variety, composition, selective focus, processing - everything about them works so well
Posted 07/07/2019 - 23:11 - Helpful Comment
Absolutely agree on the non support side, just not viable when mooching around bushes and ditches 😂
Non flashed shots produce a quality that flashed shots dont have, I really like getting out with my 135mm and tubes, no flash, when the light permits.
But sometimes if its absolute detail I'm after, then flash will be used, it is of course all about balance, and for me it's not so much a case of trying to blend both, but I see both as different styles, and each has its place, for me anyway. (And I couldn't choose one over the other)
Posted 08/07/2019 - 09:26
Super set David... particularly like the grass snake and the hoverfly on the flower... very strong across the board...
Best
Best
Posted 08/07/2019 - 09:29
Totally agree. But you've got the compromises spot on with this set. I like 'em all, with the first two having the edge for me. Everything is a compromise with macro, especially if you're doing it outside with live critters and no controlled conditions.
You must have had rain recently in Sheffield. I had to top up my pond yesterday, not enough water for a paddling frog at one end, let alone a grass snake.
Posted 08/07/2019 - 12:37
Superbly well shot, I think you wimped out a bit in not shooting the grass snake with the 100mm macro + ext tubes, what's wrong with
Chris
Posted 08/07/2019 - 15:23
Great set as always
Brian.
Brian.
Posted 09/07/2019 - 22:32
Sincere thanks for the comments everyone, I really enjoy macro photography, although it does take up a lot of time!
Posted 10/07/2019 - 08:55
Snakes in the garden, are you sure it's not a zoo you're in ???
Damn St Patrick for banishing all the snakes from Ireland
They are cracking shots though.
Just a question not a criticism, did the WB. Shift between both snake shots.
Colour reproduction in first, is much more pleasant, more magenta in the 2nd one.
Again though,
Cracking set.
Again though,
Cracking set.
Posted 10/07/2019 - 22:15
Again though,
Cracking set.
Hi Derek, I'm really not sure what happened, these were processed with identical WB settings, I even processed them twice to make sure, but for some reason the second one came out completely different. I can't explain it, these were the only 2 shots from the day that looked so different!Snakes in the garden, are you sure it's not a zoo you're in ???
Again though,
Cracking set.
Posted 11/07/2019 - 22:06 - Helpful Comment
The very first bug stands out for me, lots of interest generated by minimal elements, and the light touches of purple against the multiple shades of yellow add to the dynamics.
Posted 22/07/2019 - 01:08
Wonderful pictures. I also have to agree with David about composition and natural light. Have you tried cranking up the ISO Derek? Not being a flash user nor a super mega macro type I don't know whether you could still get the sheer image quality that sets your work apart.
Sheffield,
England
1. Hoverfly on Wild Flower - Pentax-A 50mm + Tubes
2. Tiny Fly on Water Forget-me-not - Pentax 100 Macro + Tubes
3. Grass Snake in Pond - DA*300
4. Grass Snake again - DA*300
5. Unknown Fly (Wasp?) - Pentax 100 Macro + Tubes + diffused flash
6. Unknown Fly again - Pentax 100 Macro + Tubes + Diffused Flash
7. Hoverfly on Wild Flower - Pentax-A 50mm + Tubes
8. Hoverfly on Wild Flower - Pentax-A 50mm + Tubes
9. Hoverfly on Wild Flower - Pentax-A 50mm + Tubes
10. Unknown Spider, in Reeds near pond - Pentax 100 Macro + Tubes
11. Unknown Solitary Bee - Pentax 100 Macro + Tubes + diffused flash
12. Unknown Solitary Bee - Pentax 100 Macro + Tubes + diffused flash
13. Unknown Solitary Bee - Pentax 100 Macro + Tubes + diffused flash
14. Unknown Solitary Bee - Pentax 100 Macro + Tubes + diffused flash
