FS Pentax k5 + DA 18-135 WR, Please read!
mivoligo
Posted 21/01/2020 - 10:57 Link
For sale used Pentax k-5 with a lens and other stuff like box, cables, charger, 2 original Pentax batteries, manual, strap.
Looking for £300 for all the stuff.
Shutter count is less than 17 000. Everything works BUT there are few PROBLEMS:
1. There's a bit of dust particles under the screen
2. The lens produces a circle artifact on images as you can see on the sky picture in the top right corner
3. The most important problem is that the selected programs don't work properly if not in "live view" mode. (In "Live view" mode everything works fine) For example if I select Av, the shutter speed value is never selected properly. It always is the smallest possible value of 1/8000 s. I've used the camera in full manual mode (M) so it wasn't much of a problem for me.
Let me know if you have any questions.
alfpics
Posted 21/01/2020 - 11:32 Link
Does the lens produce the artifact at all focal lengths and is the artifact always in the same place? It looks a bit like a dust spot on the sensor from the image you have posted and if so, with care, can be dealt with!
Andy
mivoligo
Posted 21/01/2020 - 11:52 Link
Yes, it's always in the same place but its size changes a bit with the focal length change.
alfpics
Posted 21/01/2020 - 12:09 Link
And the size and darkness will change as the aperture changes? I still think it is a dust spot on the sensor and not the lens being at fault.
Andy
mivoligo
Posted 21/01/2020 - 12:27 Link
Just done some tests. Indeed it looks like the darkness and the size of the spot changes with the aperture. With high number like f16 it's darker and smaller than with f4.
alfpics
Posted 21/01/2020 - 12:30 - Helpful Comment Link
It is a sensor dust spot then!
Andy
mivoligo
Posted 21/01/2020 - 12:32 Link
Thank you
MrB
Posted 21/01/2020 - 13:42 Link
People might be interested to know whether this is a problem only when using the 18-135, or if it applies to other lenses also.
mivoligo
Posted 21/01/2020 - 14:18 Link
It applies to all lenses I've tried.
MHOL190246
Posted 23/01/2020 - 12:41 Link
It is probably a daft question, but have you tried resetting to factory settings
fsge
Posted 23/01/2020 - 13:12 Link
just a spot on sensor, easy to remove
mivoligo
Posted 23/01/2020 - 14:35 Link
Yes, I've tried that. Also I've updated the firmware but nothing helped.
mivoligo
Posted 24/01/2020 - 10:19 Link
Sold. Thanks.
