FS: Sigma 8-16mm, FGZ360 flash, Travel tripod
Posted 05/06/2014 - 16:41
Posted 05/06/2014 - 23:08
I'm interested in the flash if it's all in order apart from the battery door.
Posted 06/06/2014 - 09:06
Hello,
Other than the battery door the flash is perfectly fine.
Sigma 8-16mm - Sold
Sigma 8-16mm - Sold
Posted 08/06/2014 - 21:55
I'm interested in the tripod. Might you entertain a slightly lower offer?
Rob.
Rob.
Posted 10/06/2014 - 08:57
I would consider £65 for the tripod.
FGZ360 reduced to £60.
Posted 10/06/2014 - 10:03
Hi I would like the tripod.
Rob
Rob
Posted 11/06/2014 - 08:33
Tripod and flash now sold.
Urgently need to raise some money so the following is for sale:
1x Sigma 8-16mm.
Good condition. Front and rear elements are clear. There is some minor dust inside but I've never noticed it affect image quality. Comes with the original box and soft carry case. Probably my favourite lens but its also the one that'll get the most cash so it must go.
£315 including RMSD.
Sirius T-005X tripod, its an excellent travel tripod, weights approx 1kg, folds down very small. I purcahsed it recently for a trip to Costa Rica with many long hikes and it served its purpose very well.
Offical specs:
Material: aluminium alloy, Colour: blue
Height: 10,5 - 130cm, pack size: 30cm
Weight: 1,0kg - Max. load capacity: 4kg
5 Sections, Tube diameter 10-22mm
Includes the original box but not the bag at the moment as I can't find it. Should I find it, it will be included.
£70 including delivery.
1x Pentax FGZ360.
Good condition although the tabs on the battery door have broken off. Fairly common for this flash I'm told. The door will hold on if the flash is in a stationary position or moved around gently. So for studio/macro use its fine. Can't run around like a loony with it on though.
£65 including postage.
Pictures to follow tonight.
UK postage only.
