FS: Pentax SMC-M 35mm f/2.8 lens
Posted 23/06/2012 - 23:46
Hey John, I'm interested in this one. Any chance you could upload some pictures please?
Kamil
Kamil
Posted 24/06/2012 - 13:58
Is the aperture sticky ?
Posted 24/06/2012 - 19:52
Hi Algi,
That's the one thing I hadn't checked, having done so I've discovered it is sticky (are you telepathic or is it a common problem?). I have used it on both film and digital without problems, but I'm not happy with it's condition and will have to withdraw it from sale.
Algi: Thanks for asking the question, I wouldn't have wanted to disappoint a prospective purchaser.
Thanks for those who looked at it.
John.
John.
Posted 25/06/2012 - 08:41
It's a common, but not serious problem with that lens.
If you work the pin a few times it goes away, but it's
better to check it each time you use the lens.
Because all the 35mm f/2.8's seem the same I would still
sell it for about £40. It's an excellent performer and
very good wide open. I've still got one and rate it very
highly. Mine also has the sticky aperture.... no idea why
it effects just that one lens. I was going to strip mine
down, but the 5 screws on the baseplate seem glued. I
snapped the head off a £5 screwdriver trying to undo
them.
them.
Posted 26/06/2012 - 09:50
If you try stripping it down this (£4.89) screwdriver is an exact
fit for the M lenses rear mount link
If all else fails with M lenses the aperture lever can be cut
off leaving the lens as a pre-set. This has the advantage of
making Av usable at all apertures. With a 35mm you can leave
it set on f/8 and infinity focus plus Av and it will quickly capture
anything from about 3M to INF using it as a quick point and shoot.
Posted 26/06/2012 - 21:24
You can do it that way, but I prefer to set the lens on INF.
It's very difficult to accurately set 8M hyperfocal distance
on a wide angle lens.
You need to make sure that INF is correct, but it's rare for
a Pentax prime to be out.
Posted 01/07/2012 - 20:49
Having spent some time looking at this on a camera, the aperture is definitely sticky and becomes more of a problem at smaller apertures (the green button doesn't stop the lens down completely before it re-opens it after metering). The stop-down switch around the shutter release will stop it down completely.
Reduced to £35 with UK postage, bank transfer or cleared cheque.
John.
John.
Posted 06/10/2014 - 20:05
Hi All, please read all of this post for the background.
This lens has a sticky aperture. It has been used without any noticeable problems on manual film cameras with monochrome film (K1000, MX), but when using the GREEN button on a DSLR the aperture doesn't always stop down fully before the camera takes the metering (the film cameras open-aperture meter).
Anybody interested in making an offer?
Regards,
John.
Regards,
John.
Lancashire
Good condition, some slight dust inside it but no fungus or oil on the aperture blades. Includes generic caps, £50 including UK postage. Photos on request.
Payment by bank transfer (preferred), paypal, or cleared cheque.
John.
