FS: Pentax 1.7 AF adapter - Excellent
Posted 03/08/2013 - 13:38
There is a tiny mark on the coating on one of the elements so I'll adjust the price to £199 (inc RMSD) - No offers. I have never noticed any impact on results
A few images...
A few images...
Posted 07/08/2013 - 08:18
There have been a few questions regarding tele-converters lately on the forum, which reminds me that not everyone on the forum is at the same level of geekiness (yet ) so here is a brief explanation of what this item actually is and a few of my observations and views....
The SMC Pentax-F 1.7x AF Adapter is a 6 element, SMC coated, high quality teleconverter and autofocus adapter. The magnification is 1.7 times (as the name suggests) which loses around a stop and a half of light so it will turn a 50mm f1.4 lens into an 85mm f2.4 lens (as an approximate example) but where it really differs from standard converters is that this allows the use of manual focus lenses as autofocus.
There are a few caveats regarding the MF to AF magic, it does require that you set the approximate focus position on the lens first - then partially pressing the shutter button on your DSLR will activate the AF converter and "fine focus" it for you, also it is only really recommended for lenses with an aperture of around f4.5 or greater (wider) as the AF may not be able to lock in lower light conditions (true of other converters I believe).
It does have the electrical contacts that carry information through between the lens and the camera, allowing the use of most (if not all) exposure modes. It can be used with Autofocus lenses as well as manual, but the AF functionality of the adapter over-rides the lenses so the same "pre-focus" is required.
This "pre-focus" technique becomes very quick in actual practice, you hardly realise you're doing it after a few times.
Many rate this as amongst the best in terms of image quality, I agree that it is in the top few (the Pentax 1.4x being better, but manual only) - i don't recommend it (or any other teleconverter for that matter) to be used at maximum aperture with ultra-fast lenses (i.e.1.2 or 1.4) as the results can look a little lacking in contrast or slightly soft, but stopped down just 1/2 a stop it can deliver excellent results. Generally I wouldn't recommend teleconverters for use with zoom lenses, although if you're going to then this is probably one of the better ones to do it with.
This really can open up your world of manual lenses, particualrly useful if your bit of an old geek with gradually worsening eyesight (like me).
I hope this helps for those of you who are unfamiliar with this item
Posted 07/08/2013 - 11:41
Here is an (old) official manual for the "SMC Pentax-F AF Adapter 1.7X":
http://c758710.r10.cf2.rackcdn.com/files/support/manual/275_1314744958-112672920...
(via http://www.us.ricoh-imaging.com/support/download-details/275 )
"In the case of a lens faster than f/1.7, the compund maximum f-stop becomes f/2.8"
There are also some interesting details about the range of focus.
This adapter is very useful with e.g. MF 300/2.8 lenses.
Posted 07/08/2013 - 13:42
Good price for a fantastic bit of kit!
For anyone with a DA*300mm, this device turns it into a great, hand-holdable 510mm Telephoto and gives great image quality. Takes some getting used to learning to use both manual focus and the auto focus throw together but when mastered it's brilliant.
Posted 09/08/2013 - 18:23
Image taken this afternoon with the AF converter and a 300mm lens....
and a crop....
No sharpening, just a jpeg out of camera with a little bit of "fill light" in Picasa
and a crop....
Posted 09/08/2013 - 21:44
+1Good price for a fantastic bit of kit!
If I didn't already have one (I paid more) I'd jump at this chance.
Posted 09/08/2013 - 22:02
Is the mark the area that looks like grease mark at about ten o clock on picture one
Posted 09/08/2013 - 22:26
pm sent
Posted 09/08/2013 - 23:07
pm sent.
Posted 10/08/2013 - 11:35
payment sent mike-p's photo was huge incentive
Thanks Pete
Thanks Pete
Posted 13/08/2013 - 11:35
Arrived today tried the 300 on it fine just wish it wasnt so dull out
Worcestershire
Price £225 or nearest reasonable offer (inc RMSD)
UK Only, Bank Transfer, Cheque (cleared), Postal Order or Cash on collection, Inspection Welcome.
