FS: DA17-70 and DA16-45
plis
Posted 31/01/2013 - 15:12 Link
I decided to sell lenses what I do not use. Both have some issues as explained below. I am describing them detaily to be fair.
Shipment from The Netherlands. I am sure we can find the most suitable way when we agree on the transaction. Each offer will be considered.
DA 17-70
External condition: very good with box and hood.
It has very common for this lense issue of hunting in low light in range of 60-70mm (at least with my K-r). The issue is well described on Internet. You can either live with it (as I did) or get it repaired. It has also zoom creep.
Price: I will consider each offer.
DA 16-45
External condition: good without hood (I use the one from DA 17-70 as it fits perfectly).
It has a small crack on the hood mounting (visible on the picture). With my K-r it has a problem to lock focus on wide end. I read, it is quite typical for this lense (and other wide lenses) on Pentax. I do not know if it will be better with K-5 or so. When I use it, I try to focus on more contrast or closer objects and it works. Anyway, description of this issue can be found on Internet.
K-S2 + T28-75 + DA10-17 + DA18-135 + HD55-300 + LTD 21, 35, 40, 70 + Super A + A28 2.8 + A50 1.4 + A50 1.7
obione
Posted 31/01/2013 - 15:27 Link
I Have never had a problem with my 17-70 SDM lens at 60-70 mm,it also worked fine through-out the zoom range on either off my K-5 or K-5ii
k-5, K-5ii,60-250 f4, 50 f1.4 af,17-70 f4, 100mm macro wr,siggy 10-20 siggy 100-300f4
plis
Posted 31/01/2013 - 17:09 Link
I never had the opportunity to use it on anything else than K-r. Different autofocus system might count as well. Anyway, I described the issue I have...
petros205
Posted 01/02/2013 - 11:33 Link
Hi, can you send me a pm so i can make you an offer?
As a new member I can't.
K-5II, Da 10-17mm, Fa 50mm f/1.4, af-540fgz
sigma 18-125mm hsm DC, sigma 70-300mm DC
plis
Posted 04/02/2013 - 20:55 Link
PM received and replied.
plis
Posted 05/02/2013 - 08:08 Link
Both lenses now sold pending shipment.
