FS: DA* 60-250mm - With FF mod & spare baffle!
Posted 16/10/2016 - 12:11
Pardon my ignorance, but what is the baffle for and how easy is it to put back?
SMC Pentax-DA L 18-50mm F4-5.6 DC WR RE; SMC Pentax-DA L 50-200mm F4-5.6 ED WR; SMC Pentax-D FA 100mm F2.8 Macro WR;
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE; SMC Pentax-FA 80-320mm F4.5-5.6; HD Pentax DA AF Converter 1.4X AW.
The 50-200 and 80-320 will be sold assuming I like my new 55-300.
Posted 16/10/2016 - 21:47
As I understand it the baffle is a mask to cut out light which falls beyond the edges of the sensor and could only have a negative effect.
As this lens was designed for aps-c the baffle is sized accordingly. There have been reports (I haven't checked them out myself) that removal of this baffle helps the 60-250 reach full frame coverage.
Posted 17/10/2016 - 11:28
With the original baffle, the lens does still cover the whole full frame frame (hope that makes sense) but removing it reduces the effect of vignetting. Even with the the original APS-C baffle in place FF images can be produced successfully, even at full aperture, though they may need some slight vignetting removal, depending on the subject. Less so with the modified baffle.
If anyone's interested, there is a thread on the USA forum about it:
http://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/304092-da-60-25...
The 60-250 is a great lens, with or without the modification and definitely useable on full frame which isn't surprising as the lens was originally designed for full frame!
I feel for FF use, getting one with the modification made is possibly worthwhile, but I don't think I would bother making the modification myself, even for use on the K-1
Taken at 250mm at full aperture (f4) on an unmodified 60-250mm. If the lens had been modified I doubt it would have made any difference!
Posted 17/10/2016 - 11:45
Thanks for the extra info - I had made the assumption that there would be significant vignetting on the K1 unless the modification was done, I look forward to giving the pairing a run-out shortly
Posted 17/10/2016 - 12:09
Thanks to the replies, they have pretty much answered what the baffle is, my interpretation is more along the lines of the lens being deliberately 'crippled' so as not to be seen to be producing a full frame lens.Pardon my ignorance, but what is the baffle for and how easy is it to put back?
As for replacing it, it really is a straight forward 5 screws and 2 minute job. Removing the baffle with the dremel took a bit longer!
Posted 18/10/2016 - 23:26
Thanks for all the answers and the link from jak - thank goodness someone finally posted photos there!
It's a lens I'd like, but perhaps next time.
Posted 19/10/2016 - 14:34
Could you advise please, I assume that re-gluing would also be required?
Posted 19/10/2016 - 14:40
From what I understand, the original baffle was modified so Unlocker purchased a new replacement one which should be complete and slot back in if required - 5 screws and a 2 minute job!
Can't see any reason to want to have to do that though ::
I feel sure if you were to ask, he'd do it for you should you wish to purchase it from him. If though you were considering a K-1, it is a worthwhile modification to have which doesn't prevent it being backward compatible with older bodies. The mod has been done which might be more scary for some people to consider attempting in the first place!
Posted 19/10/2016 - 14:48
Will It not need re-gluing back to the SDM ring - or is the SDM ring part of the replacement baffle?
My camera is a K-S2, so I'd probably like the lens back to standard.
Posted 19/10/2016 - 15:15
From the picture he posted above it looks complete, ready to slot back in. The actual SDM contacts will need removing to replace the baffle and re-inserting to complete the process.
Your best bet if you're interested in purchasing is to PM Unlocker with any concerns and to reserve the lens.
If I was looking to purchase one of these today I wouldn't hesitate in obtaining this as the 'scary' job has been done. There is little point in undoing the mod which was purely to cripple the lens from being an obvious FF lens when Pentax didn't have a FF body to use it on (and to be fair, help prevent some internal reflections to improve contrast.)
If you haven't already done so, have a read through of the thread on the USA Pentax forum I linked to above.
Posted 19/10/2016 - 15:25
JAK was right in his reply, the 'scary' part of the job has already been done and there is no more gluing to do.Will It not need re-gluing back to the SDM ring - or is the SDM ring part of the replacement baffle?
The baffle itself is glued to the ring that sits on the top. Whilst using the dremel to remove the inner ring it does create heat that melts the glue but it has been glued back together as one piece again.
Don't worry about putting it back to standard if you'd like to buy it, I'll quite happily swap it back with the new one and then just swap over to the modded one should you buy a K-1, simples!
Posted 19/10/2016 - 16:12
PM sent.
Aylesbury,
Bucks.
Lens is in excellent condition and is boxed complete with pouch, manuals, genuine caps & hood.
It has a tripod mount from a DA* 300mm as that was all that was available when the original one broke (the original one is included as well for spares / curiosity!). There is only one small mark on it, visible in the picture. As usual with a used zoom lens, there is some dust internally that does not affect image quality in any way.
This copy has been modified to work on the K-1 by removing the baffle and also includes a brand new replacement baffle should you wish to put it back to factory default.
Any questions, please ask!
Looking for £650 posted or pick up from Aylesbury.
Website・Blog・Gear・Twitter・Facebook
