FS: 48 LED Macro Macro Ring Flash
McBrian
Posted 27/12/2013 - 13:34 Link
Continuing the clearout
48 LED Macro Ring Flash in as new condition, come with adaptors for 49mm - 72mm, and 4 differt diffusers.
Now before you all clog up my inbox this unit is absolutely hopeless for anything that moves, so if you are a stamp or coin collector etc. this flash/continuos light should work OK for you.
£15 including 2nd class recorded mail, bank transfer or PayPal + any fees.
[img]
https://www.pentaxuser.com/images/comment_pictures/316/316_1377629565.jpg[/img]
Brian.
Taynuiltpixels
Posted 27/12/2013 - 17:28 Link
I've been curious about getting one of these for a while - when you say not good for moving objects - can you expand? - I was thinking for close up insect work - aphids etc.
"All you ever gotta do is be a good man one time to one woman"
(Janis Joplin)
KIT: K5iis, DAWR18-55mm,FA4.5 80-320mm, Mitsuki 5.6 400mm, M1.7 50mm, M1.4 50mm, M2.8 28mm, Miranda M2.8 28mm, M3.5 135mm, M1.4 200mm, Vivitar S13.5 70-210mm, Vivitar A 2.8 90mm macro,
Sigma150-500mm F5-6.3 APO DG HSM.
swarf
Posted 27/12/2013 - 18:05 Link
You have a PM
Phil
My Flikr Page link
McBrian
Posted 27/12/2013 - 18:16 Link
Here's response to a post on Ephotozine regarding these LED flights that should help....
link
OK, maybe a blanket “absolutely useless” was the wrong phrase to use.
I have the 48 LED Meike model (same as Travor RF550D), the problem I have with these LED macro lights are based on using them to capture moving object, i.e. insects etc.
For static objects they can be useful but you have to be prepared to use wide apertures/high ISO to make the light output work for you, for use where the subject is on the move they are IMO useless. Why? Unlike conventional flash guns which typically output the desired amount of light at speeds >1/700 sec these LED’s take up to 1/100 sec to reach full brightness (they don’t flash like normal flash guns) hence your maximum shutter speed will require to be equal or less than 1/100 sec which IMO is “useless” for moving subjects.
Some other things to take in to consideration, while convention flash guns use a capacitor to power the flash tube (every flash will have the desired output) these LED guns are reliant on the charge in the batteries, as the batteries deplete the light output depletes as well, also most of these LED units state switchable full, left or right power, this setting is only available in the continuous light mode which has roughly half the lighting power as the flash mode.
I hope this is a useful post.
Brian.
McBrian
Posted 27/12/2013 - 18:31 Link
48 LED Macro Macro Ring Flash: SOLD.
Thanks for all the interest.
Brian.
