FS: 3x Hitech GND filters 100x150
Photograph titled 'Mist at Dawn' by Weston246 selected as Pentax User's Photo of the Week.
Photograph titled 'Sunset through the tree' by Oldaker selected as Pentax User's Photo of the Week.
Leeds,
UK
Specifics about the filters:
0.6 (2 stop) hard edge
0.9 (3 stop) hard edge
0.9 (3 stop) soft edge
These are the longer 100x150mm size (same as Lee) and so the hard edge filters can be used as solid neutral density as well should you wish. I'll include the plastic sleeves the filters were sent in - would recommend using a more durable form of protection out in the field though.
Why am I selling? The filters can produce a very slight magenta cast in some lighting conditions which often increases dramatically when stacking - the results are still far better than Cokin and a bit of work in post processing will remove the issue, but I've got an opportunity to upgrade to Lee which, although ridiculously expensive, will make life simpler in that regard!
I'm looking for £90 for the set - I'll cover RMSD postage in that. I can provide images if required - not a lot to see though unlike when selling a lens!
Many thanks,
James
