FS - Sigma 1.4 Converter Boxed with Case
Posted 03/08/2016 - 07:20
Bump...... reasonable offers considered.
Chris
Posted 06/08/2016 - 09:19
Final Bump before it goes to a well known auction site.
Open to reasonable offers.
Chris
Posted 06/08/2016 - 11:34
I believe the Pentax version of this is screw drive only, hence will only AF with some sigma screw drive lenses. I used to have this and it worked with my 100-300f4 and original 70-200 f2.8 (non hsm). I'm sure there is a list of compatible lenses on one of the forums - may even be in instruction sheet.
George
George
Posted 06/08/2016 - 14:33
Hi George,
I included a list taken from the Sigma web site in the initial FS upload of lenses it would work with,
Chris
Posted 06/08/2016 - 15:03
Hi Chris, I saw this and I think that list is mainly canon and Nikon, the Pentax version does not have the HSM (SDM) contacts. Compare it to an sdm lens mount and you can see. I had this tc and it wouldn't auto focus with my sigma 50-150 f2.8 as its HSM, but this is on the list still.
I believe it will work with sigma 300 2.8 in Pentax fit as this is screw drive as well as the other 2 I mentioned.
If you search on DPR or Pentaxforums I'm sure you'll find a compatible list of sigma lenses in Pentax fit, currently only have my phone and limited wi fi so bit difficult to track down. I can look later on wife's iPad.
George
George
Posted 06/08/2016 - 15:07
Thanks George, would appreciate that if you could please
Chris
Posted 06/08/2016 - 20:19
The newer Sigma 70-200mm that I have (Mk2 HSM macro) is a KAF3 lens so this won't work Bugger!
Posted 06/08/2016 - 22:37
I've put it in ebay at a starting price of £99 plus postage, if a forum member would like to offer me that, it's yours as I would prefer a forum member to have it, if your anywhere south of Birmingham, there's a good chance we can meet and save the carriage etc.
Chris
Posted 06/08/2016 - 23:12
Hi Chris, still using my phone so not as easy to search for specifics, found this on Pentaxforums, ....
Mike.P® 05-10-2009 09:10 AM
The crosses are for the new HSM Sigma lenses.
The teleconverters will not work with them, Sigma totally messed that up.
REPLY
Lowell Goudge 05-10-2009 10:25 AM
Mike has the right answer. the sigma 1.4x and 2x TCs do not support HSM (they lack the power contacts of the KAF2 mount, and sigma does not include a screw drive on the HSM lenses for back compatability.
Note also that the sigma 1.4x and 2x TCs only ever worked with a limited range of sigma lenses because the front element of the TC protrudes into the lens a little. They were specifically designed for the long fast tele zooms and primes and not as a general TC where you would want to double the focal length of a shorter lens because you were in a pinch and needed extra length
REPLY
REPLY
REPLY
Posted 07/08/2016 - 08:03
Thank you to George for all the assistance, I cant find the definitive list Mike P made on this forum back in 05/10/2009 @ 09:10am of what this will work with, but it is safe to say it wont work with any Sigma HSM lens, it needs to be a Pentax Screw drive lens like the 100 - 300 F4
I can confirm it works with the 100 - 300 F4 with autofocus as I have one, it also works with the 150 - 500 but manual focus only as this is F5.6 / F6.5 as I have one of those as well.
Chris
St Austell,
Cornwall
Suits a variety of Sigma lenses, see list below taken from Sigma's web site, works well with either the 100 - 300 ( retains autofocus ) or the 150 - 500 ( manual focus only )
APO 50-150mm F2.8 EX DG HSM AF AF
APO 50-500mm F4-6.3 EX DG HSM MF MF *3
APO 70-200mm F2.8 EX DG MACRO HSM AF AF
APO 80-400mm F4.5-5.6 EX DG OS MF MF
APO 100-300mm F4 EX DG HSM AF MF
APO 120-300mm F2.8 EX DG HSM AF AF
APO 300-800mm F5.6 EX DG HSM MF MF
APO MACRO 150mm F2.8 EX DG HSM AF・MF MF *2
APO MACRO 180mm F3.5 EX DG HSM AF・MF MF *1
APO 300mm F2.8 EX DG HSM AF AF
APO 500mm F4.5 EX DG HSM MF MF
APO 800mm F5.6 EX DG HSM MF MF
APO 50-500mm F4-6.3 EX RF HSM MF MF *3
APO 70-200mm F2.8 EX DG HSM AF AF
APO 70-200mm F2.8 EX HSM AF AF
APO 70-210mm F2.8 MF MF
APO 80-400mm F4.5-5.6 EX OS MF MF
APO 100-300mm F4 EX IF HSM AF MF
APO 120-300mm F2.8 EX IF HSM AF AF
APO 300-800mm F5.6 EX IF HSM MF MF
APO MACRO 180mm F3.5 EX IF HSM AF・MF MF *1
APO TELE MACRO 300mm F4 HSM MF MF
APO TELE MACRO 300mm F4 MF MF
APO 300mm F2.8 EX HSM AF AF
APO 300mm F2.8 MF MF
APO 500mm F4.5 EX HSM MF MF
APO 500mm F4.5 MF MF
APO 800mm F5.6 EX HSM MF MF
APO 800mm F5.6 MF MF
APO 1000mm F8 MF MF
APO 120-300mm F2.8 EX DG OS HSM
