Fried hard drive
Posted 07/10/2011 - 11:46
Ah that is fortunate you have another backup, with all my laptops, tablets & phones etc this is so easily done. I only use 2.5" portable hard drives now, the power pack issue is getting ridiculous in our house now...
Concert photography
Concert photography
Posted 07/10/2011 - 12:03
I guess you're not using the power supply that came with it then as they normally aren't switchable?
You may be able to take the hard disk from the caddy and mount it in your PC / new caddy.
Posted 07/10/2011 - 12:21
Yes, thee is a very good chance that the enclosure is blown, not the drive itself.
You can buy new enclosures pretty cheaply (try Maplin/7dayshop). Or pay a lot of money to a company to do it for you.
Posted 07/10/2011 - 12:33
It is more by luck than judgement that i have other copies of most of the work, my internal hard drive was getting so full that I started deleting from itAh that is fortunate you have another backup, with all my laptops, tablets & phones etc this is so easily done. I only use 2.5" portable hard drives now, the power pack issue is getting ridiculous in our house now...
It didn't come with a power supply, I only started using one recently as it wasn't getting enough power through the USB.I guess you're not using the power supply that came with it then as they normally aren't switchable?
According to the bloke in the shop it has gone beyond that but I think I'll get a second opinion.Yes, thee is a very good chance that the enclosure is blown, not the drive itself.
This is getting worse as I have found that I didn't have any other copies of the shots from my 2 week trip to Scotland
I am wondering if I can retrieve shots that I have downloaded into the gallery and to photobucket?
Russ.
"There are no rules for good photographs, there are only good photographs"
Ansel Adams
Russ.
Ansel Adams
Posted 07/10/2011 - 12:41
What's the actual internal drive?
As a worst case scenario, it may be possible to exchange the drive controller board to rescue yours...
...but I'd get a second opinion first. Very likely you fried the USB-SATA controller board. Possible the drive remains intact.
I use several Seagate GoFlex drives which have an unpluggable chunk at the end (so you can upgrade the main drive to eSATA, Firewire etc). It's actually a very useful USB2-SATA interface and have used it many times for just rescuing and formatting laptop drives
HTH!
HTH!
Posted 07/10/2011 - 12:50
If the deleted files are in the recycle bin you will be able to restore them.
John
John
Posted 07/10/2011 - 13:20
HTH!
Matt,What's the actual internal drive?
HTH!
I think the make is ATMI, I have looked for another one the same with no luck.Do I need exactly the same one?
John
Unfortunately John, recycle bin has been emptied to free up space
John
Russ.
Ansel Adams
Russ.
Ansel Adams
Also, you may be able to recover from memory cards, even if you have reformatted and overwritten them.
Best advice, keep everything as it is now until you have checked every possibility.
Posted 07/10/2011 - 13:55
Ah well, speaking from experience it won’t happen again.
John
John
Posted 07/10/2011 - 14:51
Have you checked inside for burning etc. I had a similar happening a few years back with a Sony recorder (I realise that it's trivial by comparison). I noticed that a fine track from the power socket to the regulator chip had fused. Soldered in a piece of thin telephone cable (huge by comparison) and hey presto it still works.
Bernard
Bernard
Posted 07/10/2011 - 15:25
I agree with MattMagic - the controller board is probably fried but if the data is valuable you can always purchase an identical drive and move the controller board over (or ask someone into electronics to do this for you). I've seen this done before with great success.
Good luck!
Good luck!
Posted 07/10/2011 - 18:30
Thanks all for your advice and sympathy. I wont give up on it just yet
Russ.
Ansel Adams
Russ.
Ansel Adams
Benfleet Essex UK
Russ.
Ansel Adams
