Focusing Screen Dust!
Posted 28/01/2010 - 14:47
Alternatively if anyone has any self clean advice, it would be much appreciated.
kind regards
kind regards
Pentax K-30, Pentax K-m, Pentax 18-55mm DAL, Pentax 50-200mm DAL, Pentax SMC DA 35mm f/2.8, Tamron AF 70-300mm Di LD, Ricoh XR Rikenon 50mm f2, Sigma 18-125mm, Sigma 10-20mm, Pentax FA 50mm 1.7
Posted 28/01/2010 - 15:38
I had the same problem not so long ago, but dust had got into the mirror box as well, so I used a Green clean mini vac, I know they are meant for sensors, but if you remove the sensor pad and use the hose it works great.
Pentax K20D, Pentax 16-45, Sigma 50-300, Tamron 70-200 f2.8. Tamron 90 f2.8 macro, The Sigma Bigma.
Nikon D700 ,nikon 14-24mm f2.8, Nikon 70-200mm f/2.8 VR.
Posted 28/01/2010 - 15:45
Thanks PentaxRocks, I will look into one of those. Could the hose scratch the mirrors etc?
Posted 28/01/2010 - 15:52
It didn't on mine, but you don't need to touch the mirror just hover over it doing gentle movements. It worked great on mine. Plus it works great for doing general cleaning of the lenses e.c.t..
Posted 28/01/2010 - 15:56
Great! Sorry to be a pain, but do you know which model I need? I have found them on Warehouse Express but there seems to be a few different models.
Thanks Again.
Thanks Again.
Posted 28/01/2010 - 16:11
Arctic Butterfly statically charged brush - meant for sensors, but also good for focusing screens.
~Pete
Posted 28/01/2010 - 16:22
Posted 28/01/2010 - 16:23
Looks interesting... thanks.
Posted 28/01/2010 - 18:58
Remove the screen, brush dust off screen, blow dust off bottom of prism with lens mount down so that dust falls out, possibly use brush on bottom of prism too then refit screen.
Please note the mirror is front silvered and very easy to scratch so avoid touching the mirror as much as possible.
Good luck
Bob
Bob
Posted 28/01/2010 - 20:01
Lesson number 1. Be careful, this is a region of delicacy beyond imagination. Things in here mark just by looking at them with the naked eye. You might find a speck in the viewfinder is a nuisance but a scratch on the focus screen or mirror can be a pain in your wallet.
Cedric
Cedric
Enjoy life
Posted 28/01/2010 - 20:02
I have taken a punt on the Green Clean Mini Vac, so I should get it on Monday. I will let you know how I get on... I hope it works as it is really annoying me every time I try and take a shot.
Posted 02/02/2010 - 21:06
UPDATE:
I tried out my Green Clean Mini Vac today and unfortunately it has not done the trick. It seems that the dust is on the other side of the focusing screen, meaning that the Mini Vac can obviously not get to it. How it got there I don't know.
I will probably have to remove the focusing screen to be able to clean the other side, but I am afraid that this will result in the screen ending up in a worse state.
ARRRGGGHHH!!! this is frustrating
Any tips for my next step would be appreciated.
So my question is... where is the best place to get the focusing screen cleaned and how much should I expect to pay?
Many thanks in advance.
