Focus adjustment on K20D/K-7
Posted 30/10/2009 - 18:32
It might cause a problem if it recognised a Sigma 100-300 as say a Pentax 300 and you then mounted a Pentax 300. It would think they were the same lens.
Barrie - Too Old To Die Young
Posted 30/10/2009 - 18:40
The Sigma lenses tend to incorrectly identify themselves, I used to have a 28-200 which thought it was a Pentax FA28-105.
I would expect that all will be well as long as your two sigmas think they are different lenses, and don't identify themselves as any Pentax lens you actually have.
but it does help
but it does help
Posted 30/10/2009 - 18:42
Try taking test images with each lens. Then check what Photome reports the lens as. If it comes up with a different description for each, you should be ok
Posted 30/10/2009 - 21:47
Find out by setting a different AF Adjustment value for each lens, then refitting each lens and checking the settings.
~Pete
Posted 30/10/2009 - 22:13
If I had a K20D or K-7 then I would .. as I don't then it's a bit difficult .. hence why I was asking the question
Posted 30/10/2009 - 23:01
I think it will remember the individual settings for your Sigma lenses each time you mount the same lens. If I had a K20D or K-7 then I would .. as I don't then it's a bit difficult .. hence why I was asking the question
Where I can see a problem is in, for example, the case of my Sigma 170-500. Photome records it as a Sigma 135-400 or 170-500.
I think a K20 would always see the same lens and go to the correct settings. But what would happen if I also had a 135-400 would it see a different lens or think it was the 170-500?
Posted 30/10/2009 - 23:34
If it's reading the lens wrongly then the SR system won't be optimal either.
This sort of thing is one of the reasons for my "Pentax only" argument.
Posted 31/10/2009 - 05:06
Mike-P wrote:
It depends on the exact lenses. I think the question can only be answered by someone with the camera and same lenses. Sorry I can't help further.
If I had a K20D or K-7 then I would .. as I don't then it's a bit difficult .. hence why I was asking the question Find out by setting a different AF Adjustment value for each lens, then refitting each lens and checking the settings.
~Pete
Posted 31/10/2009 - 15:45
Mannesty wrote:
When I tried adjusting my camera for my Sigma 180mm and 135-400 APO lenses, the camera used the same settings for both. When I PP images from these lenses, they are identified by Lightroom as simply 'Sigma' with no additional info.
Thanks Peter, that's just the info I wanted.When I tried adjusting my camera for my Sigma 180mm and 135-400 APO lenses, the camera used the same settings for both. When I PP images from these lenses, they are identified by Lightroom as simply 'Sigma' with no additional info.
When they start making a 50-500mm, 70-200mm f2.8 and a 100-300mm f4 I will happily sell my Sigma lenses and buy Pentax.
Hythe,
Hampshire UK
