focus adjustment 2
Posted 19/12/2011 - 14:00
I usaully move in as close as possible, to minimise depth of field, which I find gives the best results. A standard A4 printout is fine.
Points to note
Set the aperture to wide open.
Use natural light
Make sure the camera is secure on a tripod and set very accurately at 45 degrees to the chart.
Use a remote delayed shutter release.
With the zoom you should check at several focal lenghts, it is not unusual for variation across the range.
Regards - Steve
Points to note
Use natural light
Regards - Steve
stroud,glos
