flashgun?
balsembi
Posted 30/08/2012 - 02:37 Link
hi, i have a pentax kr for 2 years now and its about time i started to experiment with flash. problem is, i dont have a clue which flash gun to buy. please can anyone recommend a good one with swivel head. i dont want to spend to much so please be gentle.
thanks
Pentax K3 Pentax SMC-FA 50mm 1.4
Pentax Kr Pentax SMC D FA 100mm F2.8 Macro
SMC DAL 18-55mm Pentax SMC DA 18-270mm F3.5-6.3
SMC DAL 55-300mm Pentax DA 15mm HD F4ED AL
SMC Pentax-M 1:2.8 28mm
Edited by balsembi: 30/08/2012 - 02:38
Fletcher8
Posted 30/08/2012 - 07:59 Link
Sometimes the photographic road is rocky, so the ride will not be gentle. I think it would help people if you told us what you want to do with a flashgun in terms of photography. Some questions you could ask yourself and find out about are below.
Will i only use my flash on the camera?
As my skills develop will I want to use the flash off camera?
Will I need to use light modifiers in the future, such as umbrella, softbox,
Will I be using the flash only for portraits?
What other things could I use flash for?
Will I buy another flash in the future?
What features do I need from a flash?
Flash modes PTTL, Manual or HSS?
OK, that's covered some rocky ground. I personally have never used Pentax branded Flashguns, I have however used Metz which I think are great in terms of what you get for the price. The models I use are the Mecablitz 58 AF-2, does everything but not cheap and the Mecablitz 50 AF-1 a great flash with a lot of features, in my opinion best flash for the price.
The links may help answer questions in relation to flash, the best thing to do is to research flashguns and prices and find one that suites your needs and pocket.
http://pttl.mattdm.org
http://www.metz.de/en/flash-units/product-ranges.html
I hope the above is of some use.
Gareth
Fletcher8.
Edited by Fletcher8: 30/08/2012 - 08:02
wvbarnes
Posted 30/08/2012 - 08:25 Link
I rarely need flash since having Pentax DSLR's as its low light capability is so good. I use the built in flash turned down by two stops when I want a bit of fill in.
I have the Sigma EF 610 DG I picked up for £99 which has a built in flash reflector for close up portraits, a low power 7 degrees tilt down for close ups, a wide zoom fresnel pop down, turns all directions and has full Pentax TTL. Only two manual power options and if you want faster than 1/180th a second you'll need the posher model.
I also have an off camera TTL lead and a flash bar/grip for about £7 each from 7 Day Shop
