flash trigger questions [again I suspect]
Posted 07/08/2010 - 18:30
Interfit and other manufacturers make IR triggers that sit in the hotshoe of the camera.
These will trigger studio flash, but you do need to check that they will trigger your Metz flashes.
Posted 07/08/2010 - 18:34
The wireless triggers and receiver only use the middle contact so just the trigger. The only flash modes you can use on the flash are manual or auto.
btw P-TTL means Preflash Through The Lens I believe so you don't want to use that if you don't want the preflash.
BRISTOL ENGLAND
Since this also seems to mean the preflash goes of it stops me using any remotes that are triggered by flash as well, and means I have to use either manual exposure setting or a non A lens to avoid this.
Before I mess up any more I assume the wireless flash and trigger[s] that seem to be cheap or very expensive dependant on brand and source[ebay]are the answer.
Do these trigger and receivers purely act instead of the flash as a trigger and the wireless communication from the camera still pass pttl info to the Metz flash with these trigger and receiver units? Or am I again barking up the wrong tree?
Alistair
