Flash OFF
Posted 23/07/2011 - 17:06
NikonToPentax wrote:
I know, if I don't pop up the flash, it won't fire, but is there a setting where you can tell the camera to keep the flash off and bump the ISO/slow the shutter.
I'm a bit confused like you said, if the flash isn't pop-up it won't use the flash and neither use it for metering.I know, if I don't pop up the flash, it won't fire, but is there a setting where you can tell the camera to keep the flash off and bump the ISO/slow the shutter.
You may get a warning that the camera wants to use the flash but if you don't pop-up it it will meter like normally.
So there is no need for an off setting.
When the flash is down the flash is off.
Posted 23/07/2011 - 23:21
Ok that's what I really wanted to know. The metering bit when flash is not popped up.
Discovering the joys of photography with Pentax
In the sky
The Flash button brings only AUTO flash and other modes
