Flash isolator
Posted 04/01/2009 - 18:18
Or you can make your own if you are that way inclined.
These are the basic components required
& this is one I made earlier, built into a hotshoe adapter.
I have also built this circuit into an old Vivtar 273 which had a trigger voltage of 327v! It is now safe at 6v. Couple of images here >>>>>>>> link
Andy
Andy
Posted 04/01/2009 - 19:30
First check if you need it.
Put a voltmeter across the flash terminals while the unit is charged.
You won't find many flashguns that have a voltage of more than about 20. And that's fine on a Pentax.
For the price of a Wein you could buy a suitable second-hand flashgun.
Posted 12/01/2009 - 21:51
All good advice but a lot of older flashes have trigger voltages over 100v. I have several that have a trigger voltage of 200v+. Most newer flashes will have a low trigger voltage.
Andy
Andy
Posted 12/01/2009 - 23:48
That mirrors an interesting discussion I had with Pentax last summer, prior to buying a K10D, re the compatibility of all my equipment and while lens etc were all fine the one thing I was told was,
"do not directly connect my Vivitar 283 to the hot shoe adaptor or any flash connector"
it will destroy the camera.
I have a full 283 kit (use it on my old KM) with grip, bracket, filters etc and would dearly love to use it with my K10D but I am almost resigned to getting an AF540.
Digital: K20D+D-BG2 Grip, K10D+D-BG2 Grip, DA* 300 F4, DA* 50-135 F2.8, DA* 16-50 F2.8, DA 17-70 F4, DA 50-200, FA 100-300, AF540FGZ, F Remote release
Analogue: KM, 200mm M,135mm M, K 2x Conv, 28-80mm A, 55mm M, 28mm M, Vivitar 283
Other: Sony PC Digicam,2x Conv,0.7x Sea&Sea wide conv,Sea&Sea Underwater housing, GreenForce 2 x 50W HID lights + double capacity battery, Fujitsu F31 and Underwater housing, Nikon 7900+Underwater Housing
Posted 12/01/2009 - 23:54
Peter,
Check the trigger voltage of your 283 - mine is under 20v and I have used it extensively on my Samsung GX1S without any damage.
As I understand it trigger voltage is dependent on where and when it was manufactured some 283s are over 200v some under 20v.
Did Pentax specify a safe trigger voltage for the K10d?
Posted 13/01/2009 - 00:21
haydnw wrote:
Peter,
They mentioned a figure sub 20V, but said that its better to be in single digits. I will find some batteries and stick a digital volt meter across the contacts and see what I get.Peter,
Posted 13/01/2009 - 00:34
Offer Andy/B1gdaddy something to make you one of his hotshoe adaptors. Would likely to be a fraction of the cost of a new flash (even the sort that comes on rolls and can be written on )I have a full 283 kit (use it on my old KM) with grip, bracket, filters etc and would dearly love to use it with my K10D but I am almost resigned to getting an AF540.
Kris.
Posted 13/01/2009 - 09:12
I used to have an old Metz flashgun and it didn't have a flash test button so, I used to short the coax plug with a ballpoint pen. I then noticed that none of my pens would work (to write with). When I looked at the tips of the ballpoints the balls had all been welded to the brass bodies
I've since used a non-powered slave flash receiver/trigger when I use a powerful flashgun fired by the deflected flash on the camera.
shim
shim
Posted 13/01/2009 - 09:33
b1gdaddy wrote:
The Pentax AF400t is 100v - it says so on the rating plate. Works fine with digital bodies.
All good advice but a lot of older flashes have trigger voltages over 100v. I have several that have a trigger voltage of 200v+. Most newer flashes will have a low trigger voltage.First check if you need it.
I know that a wireless trigger would do the job, but a neat hot shoe adapter could be a useful no fuss gadget to have handy sometimes.
