Flash Help
get a couple umbrella stands, and have fun!
I went through a similar experience and I bought some cheap optical slaves off ebay for 6 quid each. These work fine indoors when the salves can see the flash or an IR transmitter on the top of the K10D but they just don't cut the mustard outside and you sometimes have problems if the slave sensor is not facing the camera.
So then I went down the ebay radio trigger route and I'm totally over the moon with them. Have a search for the Cactus V2s on ebay via the seller gadget infinity. A transmitter and receiver pack was about 17 pound and extra receivers are about 10 pound each. There are two versions the v2 and the v2s which work for lower voltage flash units. eg. Modern day units.
Rob.
Harry
20 years
First i have to say i know nothing about flash equipment and i apologise for the Minolta word.
I have been given some Minolta stuff.
1. Minolta program 2800 AF flash unit.
2. Minolta program 1800 AF flash unit.
3. 2 X off - camera shoe.
4. 2 X cable ex.
5. 1 cable oc.
6. 1 triple connector.
My main question is can this stuff be used with my Pentax K10D.
If so in what way. If not is E-Bay the answer
