Flash gun on a budget
champywoo
Posted 18/05/2012 - 12:28 Link
Can anyone recommend a reasonably priced flash gun to use with a K-5? I would prefer one with tilt and swivel to enable to bounce the flash off the ceiling or walls.
Pentaxophile
Posted 18/05/2012 - 13:33 Link
Are you happy using it manually (adjusting the aperture/ISO on the camera to give the correct exposure)? If so there are lots of very cheap manual options e.g. Pentax AF280T, AF240Z etc, on ebay. The Pentax ones are safe to use on DSLRs although they were designed for film.
I did have a modern auto flash gun a couple of years ago (AF360GZ) which was pretty good, but I didn't find it that much easier to use than a manual flash. I found myself adjusting the settings manually anyway! If you are looking for an auto flash, make sure it is P-TTL compatible. The cheapest bounce-capable one appears to be the Metz AF24 AF1.
Edited by Pentaxophile: 18/05/2012 - 13:37
sterretje
Posted 18/05/2012 - 18:01 Link
One can happily live with an automatic flash that does not have pTTL functionality; why would it need to be pTTL compatible? I don't understand your statement.
SteveEveritt
Posted 18/05/2012 - 19:01 Link
I bought a Pentax AF-500ftz for £50, its the canine undercarriage. it works in slave mode and has a strobe function.
It is TTL but not pTTL (could someone please explain the difference)
Edited by SteveEveritt: 18/05/2012 - 19:03
gartmore
Posted 18/05/2012 - 19:28 Link
TTL was the the through the lens metering system used by Pentax up until the *ist DS or thereabouts. They then changed to P-TTL which uses pre-flash to work out the exposure. Not a step forward in my opinion but it gives good results in some tricky mixed lighting situations. Some of the earlier DSLRs can use both systems but the later ones are P-TTL only.
SteveEveritt
Posted 18/05/2012 - 22:09 Link
Thanks Ken, I have a K-7 and if I leave the flash on auto it seems to work OK and the flash power alters according to focal length etc. but I mostly use it/them for macro work in slave mode.
I say "them" because I was so impressed I bought another.
