flash connection problem
Posted 10/12/2009 - 14:24
Ken,
How about one of these for the Wein,
or even a Hama slave (which is what I use when I'm not using the AF360 & AF540 pair... which isn't often TBH)
EDIT: Ooops! The first one isn't the right way round But there are others that add PC connection to the flash via the hotshoe.
Posted 10/12/2009 - 14:55
Posted 10/12/2009 - 15:02
But there's the 4P connector - which is a hotshoe-to-flash lead
(I had one with my Pentax grip... but it doesn't get used!)
Posted 10/12/2009 - 15:10
Thinking laterally, if you take 2 x hot shoe adapters having female synch sockets and stack them together (not on camera), that would give you a female to female connector, albeit a very large one.
You'd then need 2 x male to female (extension) leads to join the Wein and the flash electrically.
Posted 10/12/2009 - 15:48
mentioned above
Posted 10/12/2009 - 15:54
I just re-read the post... unless I'm being completely thick (which is possible), that still isn't what I meant
I have a short 4P coiled cable with a hotshoe on one end, and the 4P plug on the other. I suspect it's the same as between the hammer head and camera (that would mount only a little way away).
With the short cable, you could connect into the Hama slave cube and not have any trailing wires.
Was that what you needed?
Posted 10/12/2009 - 16:26
take two female cables, cut the connectors, a bit of heat shrink tubing and solder. problem solved.
Posted 10/12/2009 - 17:12
Matt, Peter and Don all great ideas! Thanks.
Matt, I swear my undying love to you. I knew there was a relatively simple solution I couldn't see.
I'll be back to Calumet in the morning and swap the Wein slave for a hotshoe one. The idea of something the size of well, a peanut, plugged directly into the flash was an attractive one but not to be.
Do you realise what you have started? I can now use my 5P flashes as well.
Posted 11/12/2009 - 08:44
LOL!
Let us know how you get on
Posted 12/12/2009 - 11:44
It works! I'll post a photo of the combination later in the week.
20 years
Glasgow,
Scotland
I want to use one of them as a background light on a backlight stand which isn't something I normally do. I got a Wein Peanut Slave from Calumet this morning but discovered both it and the Pentax flash have male connectors and no one in the UK, it seems, sells a female to female sync lead or adapter.
My plan had been to fire one of the studio heads wirelessly (radio) and everything else would fire optically. Now, I can work around this and fire the AF400T using a 4P to hotshoe 5 metre cable but that means running a cable around/under the sitter. A step back in time to say the least.
I cant help thinking I've missed something glaringly obvious. Any ideas?
