Flash AF 360 FGZ problems
NSANTOS
Posted 24/03/2013 - 20:06 Link
Hello .
I can not change, the SYNC mode to the High speed Sync mode , or to the other mode.
Itīs possible the switch does not work ?
I hope to have your support
Best regards Comment Image
Don
Posted 24/03/2013 - 20:18 Link
sounds like the switch is stuck or broken?
you should be able to slide thw switch into any position, but then... the camera needs to support the mode for it to work as well.. what body/settings you using?
NSANTOS
Posted 24/03/2013 - 20:38 Link
I
Iīm using the K-5 , the switch slide to left and right , and donīt change in the display the sync mode..
I ready the manual , and the K-5 is not described in the manual, I know it's a flash old, and K-5 is very recent.
I do not know if can have influence, but even with the flash off the body does not change the sync mode,
Don
Posted 24/03/2013 - 22:06 Link
read your k5 manual.. the display on the flash won't change UNLESS it is in HS mode AND the camera chooses a shutter speed faster than 1/180 sec.
try shutter priority (Tv mode) and set a high shutter speed... see what happens..
NSANTOS
Posted 25/03/2013 - 09:14 Link
Hello
Thank you Don for your advises ..
regards
Don
Posted 25/03/2013 - 12:15 Link
hope it helps, come back if it doesn't... this is a hepful group..
