First pics with my K-r
Posted 19/06/2011 - 21:24
Focus is out on most of them.
Best setting for everyday use for most people in most circumstances is AV, and sensitivity of 200 ISO. Go to 400 or even 800 if light is poor.
(Almost) always keep shake reduction on, and remember to adjust aperture to reflect what you are photographing. Wide for the insect, small for landscapes. A small aperture keeps most things in focus, a wide one only what you focus on. But a small one requires a lower shutter speed to compensate for the reduced light reaching the lens.
Put all settings for colour, contrast, etc to neutral, until and unless you find you would prefer something different.
Novices to digital photography tend to over-sharpen and over-saturate their images. Less is more, generally.
Get and use a post-processing (image-editing) program of some sort, and use it to fine-tune your pictures. EVERY picture benefits from some adjustment.
Good luck.
Good luck.
Posted 19/06/2011 - 21:30
Thanks for the advice, I know they aren't perfect it was windy and the animals wouldn't stay still I will make the changes to my camera now and see how I go
Body: Pentax K-r & K-3 + D-BG5 Battery Grip
Lens: Pentax 18-55mm L - Pentax 18-55mm AL WR - HD PENTAX-DA 15mm F4 - Sigma 18-250mm f/3.5-6.3 DC OS HSM - Sigma 50mm EX DG Macro - Sigma 150-500mm f/5-6.3 DG OS HSM - Kenko 2x Teleplus
Flash: AF-360FGZ
Flash: AF-360FGZ
Posted 19/06/2011 - 21:33
What lens did you use for the photos above?
Posted 19/06/2011 - 21:41
A Tamron 55-300mm + a 2x adaptor, the locust was the 18-55mm that came with the camera
Flash: AF-360FGZ
Flash: AF-360FGZ
Posted 19/06/2011 - 22:35
I set my focus up so that there is only one red dot where I am focusing.
You could try this setting and see if it also works for you.
https://pentaxphotogallery.com" target="_blank">
https://pentaxphotogallery.com/images/black_link_small.jpg" alt="See my photos featured in the PENTAX Photogallery" />
Flash: AF-360FGZ
