First from my K10
Posted 30/03/2012 - 09:43
Could be my monitor, but #1 looks as though the whites are a tad grey. #2 looks great, composition-wise, but maybe a bit on the "over-exposed" side of things?? Perhaps it would be a better picture if shot in HDR mode??
Posted 30/03/2012 - 10:06
Ted
Have to say it looks as if that K10 is working well.
It also looks like it has got into the hands of a good driver.
Take care.
Take care.
Chris R.
I. El. (Eng). (Rtd).
Posted 30/03/2012 - 10:33
To quickly adjust the iso press and hold the OK button and move the front dial.
Posted 30/03/2012 - 10:48
It has an HDR mode???Could be my monitor, but #1 looks as though the whites are a tad grey. #2 looks great, composition-wise, but maybe a bit on the "over-exposed" side of things?? Perhaps it would be a better picture if shot in HDR mode??
Time to read the manual, methinks!
Posted 30/03/2012 - 22:26
If white looks grey, then it's under-exposed!Could be my monitor, but #1 looks as though the whites are a tad grey. #2 looks great, composition-wise, but maybe a bit on the "over-exposed" side of things?? Perhaps it would be a better picture if shot in HDR mode??
I do agree that the second is over-exposed (easily adjusted if you shoot RAW) and the first is perhaps slightly under-exposed (though that might have been intentional).
Posted 30/03/2012 - 23:08
Ted - when you say your K10D is slightly crippled, what do you mean?
Posted 31/03/2012 - 00:18
BTW, Ted, forget HDR - PLEASE!
Posted 31/03/2012 - 08:40
The new camera clearly works well, Ted.
Now just a few minor exposure adjustments. Levels should bring out the whites nicely in the first one and the second one's highlights are clipped. (Check the histogram: I find it's easier to bring a little more detail into shadow areas than it is to recover highlights.)
The K10 doesn't have an HDR mode. Which is nice.
Best wishes,
Robert Adams
Ernst Hass
Robert Adams
Ernst Hass
Posted 04/04/2012 - 13:06
It had been dropped, so I got it (very) cheaply.Ted - when you say your K10D is slightly crippled, what do you mean?
The lever inside which operates the iris, well, it doesn't. The motor goes, but the final drive to the lever is snapped (I think).
So, I use the camera in Av mode. Open the iris right up. Focus, then stop down before pressing the shutter.
It means I can only use lenses with an A ring, and I can't grab a shot unless I have the aperture wide open (or almost, depending on lighting.
I've also had to turn off the auto focus on the shutter button and use the one on the back of the camera.
But these aren't big problems and I can work around them. For the price, it was a no brainer!
Posted 04/04/2012 - 18:19
Most lenses will focus OK down to at least f/5.6 so can't you just leave them at f/5.6?
M42 lenses inc. pre-sets should work you can just set them to f/5.6, they should already be stopped down to that as you focus.
There might be a bit of tweaking needed with M42 lenses if they have black paint where the contacts should be.... a bit of silver paper would do. It's documented on the US forum.
Posted 05/04/2012 - 21:53
I'm with you! Still, all being said you seem to be doing well with it. Keep it up.
Wirral
Here's my first couple of snaps while I'm playing around with it.
This was taken in the house, natural ( but dim) lighting, hand held.
I did have the ISO at 1600 by accident, ( I'm still getting used to the various buttons and dials).
[IMG]http://i75.photobucket.com/albums/i296/Father_Ted/PHOTOS/K10test1.jpg[/IMG]
And this was at a graveyard beside a building site we are currently working on.
I thought this was a nice representation of life and death.
[IMG]http://i75.photobucket.com/albums/i296/Father_Ted/PHOTOS/K10test2.jpg[/IMG]
C&C??
