First crack at Milky way
Posted 27/08/2016 - 14:34
A martyr to your art. But worth it for the viewer
Barrie - Too Old To Die Young
Posted 27/08/2016 - 17:39
Second two are very well photographed. Great work.
Posted 28/08/2016 - 00:44
You failed to say that you also learned how to photograph the starry sky
Posted 28/08/2016 - 12:01
The shoes soon dried out but it took some time for my feet to defrost.A martyr to your art. But worth it for the viewer
AndrewA wrote:
I think they are excellent!!
Thanks, I'm hoping to try again in the same spot next autumn/winter with a bit more practice under my beltI think they are excellent!!
swarf wrote:
Good job!
Thanks.Good job!
K10D wrote:
Second two are very well photographed. Great work. Best regards
It was a learning experience. Both in terms of composition and technical details. I like the result of the wider shots better but the Sigma is significantly slower than the DA* 16-50.Second two are very well photographed. Great work. Best regards
I also learnt how to convince myself that the cows I could hear at the other end of the paddock
Posted 30/08/2016 - 07:50
Lovely images
Posted 30/08/2016 - 11:25
cardiffgareth wrote:
Lovely images
Thanks.
Lovely images
Posted 30/08/2016 - 12:13
I think they're very good, I'd certainly like to get something anywhere approaching that kind of quality.
Back in Oz
At ISO 3200 the noise is pretty bad, I've given them a run through Topaz Denoise 6 but I was pretty conservative to avoid loosing too much detail and ending up with a smooth mess.
First is with the Pentax DA*16-50mm @ 16mm f4 30s
[IMG]http://www.pentaxforums.com/gallery/images/3698/large/1_160528_IMGP3119.jpg[/IMG]
Next is with Sigma 8-16mm @ 8mm F4.5 30s
[IMG]http://www.pentaxforums.com/gallery/images/3698/large/1_160528_IMGP3135.jpg[/IMG]
Last also with Sigma 8-16mm @ 8mm F4.5 30s
[IMG]http://www.pentaxforums.com/gallery/images/3698/large/1_160528_IMGP3139.jpg[/IMG]
I learnt a few lessons along the way: don't go into a dark cow paddock at night in canvas shoes; don't point the lens straight up if you want to avoid condensation settling; windmills often have big puddles of water near the base; and it takes a long time to remove thistles and burrs from your trousers.
