Firmware download
Posted 07/07/2008 - 16:01
Did you follow the instructions on how to turn the camera on with the prepared card in the slot ?
Posted 07/07/2008 - 16:07
You're on the right lines, copying to the root directory simply means copying to the card but *not* placing it in any folder or sub-folder. With the K10D you have to insert the card and then switch the camera on whilst simultaneously holding down the "Menu" button - check your instructions to be sure, but I'd bet the procedure's the same for the K20D. Make sure your battery is fully charged before starting!
Joining the Q
Posted 07/07/2008 - 19:00
Peter,
I copied the file on to the card (not in a folder) turned the camera on pressing the menu button, the version came up but it did not load up the new software, after 5 seconds the camera just came on as normal.
Posted 07/07/2008 - 19:56
Did you extract the exe file from the download ?. Forgive me for saying, but unless you have some idea what you are doing you are in danger of screwing up the firmware in your K20d. Which will then cost you to get sorted !.
BJ
BJ
Posted 07/07/2008 - 20:17
Merlin might have the answer to your problem. The file you download looks like a microwave oven. You need to double click it and it produces a BIN file and a read-me file. Make sure you copy the BIN file to the card.
Also format the card first in the camera. Then add the BIN file.
I would download the firmware again in case it got corrupted. Make sure you use the right one....i think it is different for mac/windows.
Posted 07/07/2008 - 21:42
Yes I extacted the file and copied the BIN file to the card but nothing happened. the instructions say 'copy the file to the root directory on the card' not just 'copy the file to the card', so there has to be a difference between the 2 processes. I have root directories before, just not sure how I got to them ?!?!?!?
Posted 07/07/2008 - 21:47
Yep you just copy the file so that it sits next to any other folder that might be there, not in the other folder.Yes I extacted the file and copied the BIN file to the card but nothing happened. the instructions say 'copy the file to the root directory on the card' not just 'copy the file to the card', so there has to be a difference between the 2 processes. I have root directories before, just not sure how I got to them ?!?!?!?
Did you re-download the firmware and format the card in camera first?
Posted 07/07/2008 - 22:12
It worked chaps, thanx very much
Middlesbrough,
England
