Firmware
Posted 03/01/2008 - 23:52
I am either confused or dim
Don't be ashamed to be the former, and being so does not imply the latter.I am either confused or dim
Anyone that says they haven't been (more than once, probably) is either lying, or knows much less than they imagine.
They don't exactly bend over backwards to make this stuff easy.
However, for once, the answer is easy...
I suppose my question is, is it necessary to upgrade up to 1.20 before I can install 1.30?
No. You can if you want (although there's no advantage in doing so), or you can go straight to 1.3.I suppose my question is, is it necessary to upgrade up to 1.20 before I can install 1.30?
Just use a fully charged battery, and follow the instructions to the letter.
Welcome!
Posted 04/01/2008 - 08:26
I can confirm that you can just go straight to v1.3, since that's what I did recently with my work camera.
but it does help
but it does help
Posted 04/01/2008 - 09:32
Make sure your camera currently has firmware version 1.00 through 1.20.
Your camera, as you said, has version 1.00. Therefore that statement is perfectly correct Make sure your camera currently has firmware version 1.00 through 1.20.
(They say that, because if there was ever a 1.40 you can't downgrade to 1.30 ... at least not normally!)
Just go ahead and put 1.30 straight in and enjoy
Posted 05/01/2008 - 00:01
Thanks for the advice. Would I be correct in thinking that, if I do the 1.3 install, it will include all the improvements and bug fixes covered by the previous firmware upgrades, i.e remote flash and more comprehensive configuration of e-dials, etc?
Posted 05/01/2008 - 00:17
Yes. In terms of the actual feature set, the upgrades are cumulative, that is to say, each includes all the previous additions, and adds to them.Would I be correct in thinking that, if I do the 1.3 install, it will include all the improvements and bug fixes covered by the previous firmware upgrades, i.e remote flash and more comprehensive configuration of e-dials, etc?
It's computer programming, at the end of the day, so I expect it's not actually impossible for them to introduce bugs with a later version. But it would be something of a scandal if it happened, and they'd doubtless fix it pretty sharpish.
But other than the removal, with version 1.2 IIRC, of an undocumented 'back door' that gave access to some of the very low level factory adjustments, there's no evidence that it has happened so it's not a significant concern.
Posted 05/01/2008 - 00:33
Chris,
Thanks, once again, for putting my mind at ease. Guess what I'm doing tomorow? Just as soon as my battery is fully charged!
Posted 06/01/2008 - 18:57
I have just got a K100d and would like to know how to find out how ifind out which version is on mine?
Posted 06/01/2008 - 19:07
If you type "download k100d firmware" into Google, you'll find that the first link in the search results contains precise instructions for upgrading the firmware, and includes an answer to this question.
Normally you hold down the MENU button while powering up the camera.I have just got a K100d and would like to know how to find out how ifind out which version is on mine?
Posted 06/01/2008 - 21:16
If it helps you visualise firmware upgrading, the firmware is stored on a chip in the camera, and every time you upgrade it, you're actually just downloading an entire new chip's worth of software and dumping it onto the chip
This is why 'upgrade' is a silly term, I think - 'replace' would be better.
Posted 06/01/2008 - 21:20
Just to let you know, and those who are contemplating it in the near future, that I am now running version 1.30. All that fretting and sweating wasn't justified (visions of a failed upgrade and a dead camera!). The only disconcerting thing was the read/write LED flashing continuously after the "complete" message was displayed. After switching the camera off, removing the SD card and switching it back on again, to my great relief, I was running version 1.30.
Once again, thanks to everyone who offered advice.
Posted 19/01/2008 - 18:01
I bought my K10D in early Jan 08 it came with firmware 1.0 installed. I've just upgraded to 1.30.
Very easy process to follow.
South Lanarkshire,
Scotland.
The trouble is when I went searching for version 1.10, on the Pentax website, the earliest version I was able to download was version 1.11. Even though I found the link to version 1.10 it took me to the download for 1.11 and if I clicked the link for version 1.20 it took me to the download page for 1.30.
