Firmware
Posted 26/05/2014 - 13:21
Sometimes updating is a good idea, very rarely it causes new problems that have to be addressed with another update.
Generally, you might as well update and take advantages of whatever performance improvements are on offer.
Posted 26/05/2014 - 16:20
oldhat wrote:
I see there are now three K3 firmware updates available.
I am still on the original one and wonder if there is any significant benefit it upgrading!!!:
And you ONLY need the latest. It is a full firmware build. Don't do as I have heard some others do and work through update 1, update 2, update 3.
Posted 26/05/2014 - 19:05
Many thanks chaps!!!
Posted 25/06/2014 - 21:54
Gamka wrote:
Thanks for that info, I have just aquired a K3 and was wondering if I needed to install in order or go straight to update 3javascript:;oldhat wrote:
And you ONLY need the latest. It is a full firmware build. Don't do as I have heard some others do and work through update 1, update 2, update 3.I see there are now three K3 firmware updates available.
Rob
Posted 25/06/2014 - 23:00
Being a very new camera I'd definitely suggest applying the update, as it's sure to have addressed some initial release bugs.
They generally explain what is in each update (compatibility with new lens offerings for example) but you'll never know what minor bug fixes may also be in there that haven't been specifically mentioned. There could be a lot tucked away under that 'general performance improvements' part
Posted 26/06/2014 - 08:10
Just apply the latest update
13 years
Edinburgh
