Firing old Vivitar 283 flashgun
Posted 18/02/2009 - 15:38 Link
I know there are a number of threads on topics around this problem but I can't find my specific issues.
I know I'm not going to mount my flash on the camera.
I am happy to have everything fully manual.
I have a K100D and would like to use the built-in flash to trigger one of the following:
link
or
link
or
link
I know there is a pre-flash, it mentions it in the manual, for the red-eye reduction, but it does not mention any other pre-flash. Am I right in assuming there is a pre-flash at other times? If so can it be switched off? If so, how?
My other alternative is a PT-04 Wireless Trigger
link
Does this have any issues? Does this only trigger at the main flash?
Only had the camera a few weeks and generally hate flash pictures, so want to avoid any flash on top of camera. Thanks for any help.
K100D, 18-55mm, 75-150mm Takumar, 28mm Takumar, Semi fish-eye, Vivitar 283
hefty1
Posted 18/02/2009 - 16:13 Link
Your built-in flash is P-TTL *only*. This means it will always emit a pre-flash for metering purposes (although it's so brief and so close to the main flash as to be all-but-undetectable to the human eye) and this can't be switched off. Therefore, any of the three slave triggers you've linked to will go off on the pre-flash and miss the main event.
The wireless trigger on the other hand should work just fine and will synchronise the remote flash to the shutter.
Joining the Q
mikew
Posted 18/02/2009 - 16:48 Link
I use a wireless trigger PT04 to fire a 283 remotely but I don't use the pop up flash at all - and I'm guessing you won't either.
Have you got the gizmo that allows you adjust the output of the 283? It's really useful and makes the gun more usable.
Posted 18/02/2009 - 16:53 Link
Thanks for the quick responses.
I'm glad I found this forum as I would not have known about the pre-flash problem from the manual. I could only see the red-eye one, and this is all the manual mentions.
womble
Posted 18/02/2009 - 17:38 Link
The pre-flash stuff is a pain. I couldn't get the Pentax AF360FGZ to fire consistently in slave mode and in the end purchased an old small Pentax flash to act as the trigger.
Good luck with it all.
Kris.
Posted 21/02/2009 - 18:40 Link
I have been looking into the PT-04 further. One review thinks there is the same problem with my flash frying the receiver in the same way as it would the camera.
Any comments?
Edited by mfdaustrey: 21/02/2009 - 18:41
mikew
Posted 21/02/2009 - 20:51 Link
Not fried mine yet and I must have fired 100+ shots. I measured the voltage and it's 300v so if it could it would. If you're anywhere near me, and I'm in Worcestershire, you can come and see it work.
I did have trouble getting it to fire without using the cable but that was because I didn't use the clamp that locks the shoe into place.
Anyway it's 16 quid for the PT04 so not a huge gamble given my experience.
beachboy2
Posted 22/02/2009 - 00:13 Link
These "peanut" style slave flash triggers are great. I use a SLS? version. Handy if you have a number of old flash units, especially high voltage units which should not be mounted on your camera. To trigger these slaved flashes you need another (low voltage) flash mounted on your camera. It must be non PTTL so it has no pre flash and will trigger all your slaved units. No need for any wireless triggers in this setup.
bb2
K5, K20D, Bigma, Sigma EX 105, Sigma EX 10-20, Sigma EX 28-70 F2.8, Sigma Ex 1.4TC,
Pentax 135 F3.5, Pentax 30mm F2.8 , Pentax 50mm F1.7, Pentax 55mm F1.8,
Super Taks: 35mm F3.5, 50mm F1.4, 135mm F3.5, 200mm F4
Vivitar TX 200mm F3.5,Vivitar (Komine)135mm f2.8, Vivitar 2X TC, Vivitar T4 400mm F6.3
Tamron SP 35-80,80-210 F3.8, Helios 44M, Mir 1B 37mm F2.8, Jupiter 9 85mm F2, Chinon 28mm F2.8, 3M-5A 500mm F8 etc etc
