Ffordes - Bargain grade 85mm f2
Posted 22/06/2018 - 18:13
That's a new one fungus doesn't effect the optical quality
Wouldn't touch it with a bargepole
Posted 22/06/2018 - 18:25
At least you can send it back or get it cleaned, depending on your risk appetite. As opposed to the usual shenanigans on the auction site....
Posted 22/06/2018 - 18:45
Im with Algi… Wouldn't go near it.
Stuart..
Stuart..
Posted 22/06/2018 - 19:36
If it was less than £70 I'd buy it. Fungus isn't a big deal.
All the gear with no idea
Posted 22/06/2018 - 20:38
General question about fungus on lenses like the one in question: just how difficult is it to dismantle them, clean off the fungus and then reassemble them.
OTOH, roughly how much would a reputable repair place charge to do the same work?
Posted 23/06/2018 - 07:44
Ffordes will give you a refund but only for the value of the item, not for the extortionate amount they charge for delivery. Factor in what it would cost for a professional clean and it becomes probably the most expensive M 85mm f/2 I've seen.
Posted 23/06/2018 - 14:27
If the optics were at 100% clean/mint condition before fungus then a repair brings the lens back to close to mint.
It's not hard to DIY it, the main issue is disassembling components that have been stuck together for years and years. From then it's a matter of keeping the various surfaces clean, and cleaning away fungus without damaging the coatings on the elements.
Posted 23/06/2018 - 19:26
Fungus isn't usually too much of an issue but if it,s been there a long time it can etch the glass. Cleaning is then not possible.If the optics were at 100% clean/mint condition before fungus then a repair brings the lens back to close to mint.
That shouldn't be the case for 'light fungus spots' which as they say should have very little effect on the results, at least if they're not on the rear element. They can probably be seen in the Bokeh if you inspect carefully, but otherwise will probably only reduce contrast marginally.
Posted 25/06/2018 - 11:42
Pentaxophile wrote:
so you might end up with a better item than if you bought a fungus-free lens.
You might indeed. Or you might find that the screw heads inside have been burred. Taking on a lens that requires work is always a bit of a risk. I acquired a pentax-A 16mm 2.8 FE that had a tiny spot of fungus under the front element. A specialist (Alan Marlowe) was not able to get access to the rear of the element and despite his best efforts a little of the fungus remains. I did not pay much for the lens so don't feel I have lost anything, but price is key when considering a "project". so you might end up with a better item than if you bought a fungus-free lens.
I tend to agree that the 85mm f2 is overpriced for it's condition. Why would the sellers not get the lens cleaned themselves and then price it at £200?
20 years
http://www.ffordes.com/product/18052916044651
