Feeling Chuffed
Posted 18/08/2017 - 13:34
You know you can tether it wireless to a tablet with the build in K1 wifi and a bit of Pentax free app ( image sync ) works a treat and you can fire the camera and make adjustments as well !!
Chris
Posted 18/08/2017 - 14:21
No Chris I didnt know that,, Though something does stick in my mind that ive seen it somewhere along the way.. Please could you tell me more...?
Stuart..
Stuart..
Posted 18/08/2017 - 14:38
Hi Stuart,
You need to download the image sync app to your device, then switch the K1 WIFI on and the camera basically creates it's own hotspot which the sync app will find, pair the 2 and away you go.
I've done mine, but it took some patience, suggest having the manual to hand when you do as the pairing code is in the book.
Chris
Posted 18/08/2017 - 15:15
That will keep me quiet
this evening...lol Just went to download the app. Found I had already done it previously... Must have failed to get it up and working at the time....!! Hopefully second time lucky,,,,
Stuart..
Stuart..
Posted 18/08/2017 - 15:17
Likewise, I failed first time then went back to it and cracked it, only used the app once since thou
Chris
Posted 18/08/2017 - 15:24
If I pair my K1 to the imagestnc app wirelessly can i review pictures on my ipad ?
Posted 18/08/2017 - 15:34
Not sure Peter, its a while since I've used it, I think so but try it and see !!
Chris
Posted 18/08/2017 - 15:41
That sounds like a good solution to the Electronic 360deg Continuously Rotating Panorama Head I just bought....... My neck looks like a twisted elastic band from trying to keep up with the rotating viewfinder
It would also save me from having to reverse the direction after every two turns
Posted 18/08/2017 - 16:56
Double chuffed then 😂 lol
Chris
Posted 18/08/2017 - 18:14
yes turned out to be a lot easier than I imagined... Thanks for the nudge Chris,,,
Stuart..
Stuart..
Manchester
Just dont know now, what im going to use it for....? Or how to use Lightroom....lol. As im more of a camera raw / Photoshop kind of person....
One thing is for sure...... Gonna need to aquire a longer cable !! My phone charging cable is a little on the short side.....
Stuart..
