favourite settings
Posted 07/04/2012 - 11:24
Natural. sRGB. Centre weighted metering. Premium Quality JPEG. Av or M as appropriate, usually Av generally but M for studio flash. +1 sharpness.
I think that sums it up, hope it's helpful, but that's just my preference and it might not be yours.
Posted 07/04/2012 - 12:06
Evaluative metering, lowest practicable ISO' always always full manual.
Posted 07/04/2012 - 18:03
Oh yes should have said raw always too and, like John, natural. Focus point positioned as needed per shot and/or manual focus with live view and zoomed-
Posted 07/04/2012 - 18:15
Here's mine for landscapes 95% of the time:
Evaluative mainly (spot for high contrast metering)
Centre focus point
Raw
Iso 80
AV 95% of the time
Increasingly starting to use LV, terrific for shots with motion (waterfalls etc)and great for positioning NDgrads
Simon
Centre focus point
Raw
Iso 80
AV 95% of the time
Simon
Find me on Google+ link
Posted 07/04/2012 - 23:40
For rugby
TAv 1/1000sec F4 ISO 100-3200
Posted 07/04/2012 - 23:47
johnriley wrote:
Natural. sRGB. Centre weighted metering. Premium Quality JPEG. Av or M as appropriate, usually Av generally.....
That man stole my settings Natural. sRGB. Centre weighted metering. Premium Quality JPEG. Av or M as appropriate, usually Av generally.....
Pete
K-1 K-01 Q-7
some len
Close to the Edge
Down by the River
some len
Close to the Edge
Down by the River
Posted 08/04/2012 - 12:53
M-mode
Center AF point
Center-weighted metering
AWB
RAW (always)
ISO 200 (dependant on situation) as a starting point
EDIT... This is for my K-x... Sorry,misread thread... Although I can't see that using a K5 would change them much...
Center AF point
AWB
RAW (always)
Digital:
Flash:
Film:
Digital:
Flash:
Film:
Posted 09/04/2012 - 16:07
Great thread
Posted 09/04/2012 - 16:48
Av, Reversal film, white balance to cloudy or shade 99% of the time, iso 80-10000, JPEG **** almost 99% of the time, central focus point 95% of the time
http://bhristov.com
K-3 with FA 100/2.8 Macro, DA* 300/4 SDM, Sigma 150-500/5-6.3 APO HSM, Tamron 17-50/2.8 Di II, Sigma 17-70/2.8-4.5, DA 50/1.8, M 50/1.7 and Cobra 2X TC
Posted 09/04/2012 - 18:13
I run mine in "P" program mode with the program line set to "Normal". This means I can use the rear dial to adjust the aperture, making it AV mode (which I use most of the time), or the front dial for the shutter speed, making it TV mode, without having to change the mode dial. If I mess up these settings then the green button is a life-saver putting it back into its starting position .
I use centre point focusing most of the time because it means the arrow buttons go to the function settings without having to check in the viewfinder if a long press of the OK button is needed. Otherwise there is a risk that in trying to set a function, like, say, the drive mode to self-timer, that I have moved the focus point before realising why nothing appears to be happening.
I prefer Centre Weighted exposure.
I have auto ISO set restricted to 200-800 just to make sure that I make any decision to go higher but actually usually leave ISO fixed to 200 as a manual starting point.
I have lens correction off because it seriously slows down the minimum time between shots. I do any necessary correction in post editing on my PC.
I used to just use JPEG (16M & **** quality) but have recently started started using RAW+ & DNG because I have been won-over by Adobe Lightroom. The downside is that I am going to have to increase the size of my backup network drive .
I have set the Dynamic Range Setting to Highlight Correction: On and Shadow Correction: Medium.
I have unticked a few things in the "Memory Setting" as I have messed up a few shots by forgetting that I had on a previous occasion changed something, usually the EV Compensation . I have left ticked; Drive Mode, Sensitivity, Flash Exposure Comp, Extended Bracketing, Playback Info Display & File No.
In the custom settings I have "Using Aperture Ring" (27) set to "Permitted" because I have a few old manual lenses.
I also use The "AF Fine Adjustment", (Custom 26) but I think this needs some confidence & test-commitment to set the values so would recommend a new user leaves this alone.
Like others just beware that these are my personal settings and might not work for you.
Glyn
Glyn
Posted 14/04/2012 - 18:03
Me too GlynM, I also run in P mode most of the time. Why do so many people opt for Av mode when you get Av mode and more from P mode?
I have several 'favourite' user settings. Remember, you can store up to five. At the moment mine all use P mode. I enable highlight correction and a low level of shadow correction, but the downside of highlight correction is that the minimum ISO is then 160. Perhaps I'll re-think enabling that.
My favourite, favourite user setting uses the MTF Program Line, which means the aperture is biased to get the best from the lens. I also have user modes for Fast, shallow depth-of-field and deep depth-of-field.
In Fast mode I set the fast Program line and permit higher auto ISO settings.
I think the deep depth-of-field Program Line is useful for quick tourist snapping, when you don't have time to consult DoF tables. I find that getting the depth-of-field right is my biggest challenge, moving from a compact travel zoom. I guess it becomes intuitive with experience but I think the camera could do more to assist. For instance, it could display a DoF table based on the focal length and aperture setting.
Turnberry,
Ayrshire
