Fair comment on lens rationalisation?
Posted 08/02/2013 - 19:05
I don't think it's bad advice at all, unless your friend is always at either the 18mm or 300mm end of their lenses.
From my experience with the Pentax 18-250, it is perfectly usable throughout the range (actually, it's very good - better than you'd have any right to expect given the range), but at the short end there is noticeable distortion and at the long end it's not 300mm and it does get a bit soft.
Posted 08/02/2013 - 19:26
Yes, I think you are right Graham. From what I remember reading I don't think the two above mentioned lenses are stellar at 300mm and she is currently happy with the performance of the 18-300 at 300mm.
Laindon,Essex
2 x 18-55mm
Tamron 18-200
Sigma 70-300
Sigma 28-300
I have suggested that replacing the lot with an 18-270mm or 18-250mm of any marque will leave them no worse off and perhaps slightly better off in terms of range and IQ. This is also based on the possibility of replacing the K-x with a K-30 where the 300mm range could effectively be regained from cropping with the higher resolution K-30.
Does this seem reasonable?
Dave
