FA 100-300 power zoom
Posted 30/01/2010 - 20:11
It will work, as you will have AF and AE. But in terms of power zoom if it will work, then only some of it's functions.
Will it be sharp at 320? Well, I'm not too sure. I'd say you are better off spending money on DA or DA L 55-300. It has very good reputation even at 300.
But what I wrote, is only based on what I've read. I have never owned this lens.
BR
BR
Posted 30/01/2010 - 20:15
Pentaxforums seems to think the earlier, plastic mount version (4.7-5. is better than the later one.
And no, it won't be deadly sharp at 300. If you want that and can find one. try a tok AT-X 80-400. But it will be around four times the price of the 100-300.
Bret
Bret
my pics: link
Posted 30/01/2010 - 22:32
Steve, what lenses do you already have?
Regarding the 100 to 300, as axl mentons, you will get Auto Focus and exposure, but most of the power zoom functions will not work. It'll be a fine lens if you can get if for cheap. If you can stretch to ~£250, you could get a DA55-300 new, which is very good, or as axl also mentions the "L" version is also very good, but might be available ~£150 second hand.
You say that you want to shoot birds at a distance. What kind of distance? I should point out that even 300mm on a crop body is not very good for serious birding - you would typically be looking at around 500mm or more for looking at birds at any kind of distance. Of course, 300mm is better than nothing!
You could consider picking up a mirror lens - the Sigma 600mm mirror lens typically runs at around £90. However, mirror lenses have lots of problems; their main advantage is that they can give you extreme focal lengths for a fraction of the price!
Posted 30/01/2010 - 23:09
The SMCP-FA 1:4.5-5.6 100-300mm lens will work fine on a K7, as it does on a K10/20D body. The power zoom ring also works because it gets it's power from the two contacts inside the body mount which also powers SDM equipped lenses.
The buttons on the side of the lens that are used to set start/stop zoom points on some older bodies will not work however.
I have an example of this lens that I no longer use which I am willing to sell. PM me with an offer if interested.
Most of the sigma zooms that encompass the 100-300mm range are also good performers, but no power zoom function.
Posted 31/01/2010 - 08:50
I have the earlier F version (same lens, just no power zoom. The lens mount is metal on mine). It seemed to be regarded as the best of the long zooms that I could find for sensible money, and it's not a bad performer. A little fuzzy at 300mm but usable, and the fuzziness only really shows if you crop images. Here's a shot of a sparrow on my bird feeder (heavily cropped):
Somewhere warm and sunny
Well that's the plan anyway.
