F or FA 50mm 1.7?
This topic has a poll - login to enter
Posted 10/08/2010 - 21:15
That's a tough choice, the F is *supposed* to be sharper, never had one!
The F is better built but has a narrower focus ring. The FA looks nicer IMHO and can pass more info to the camera vis eletronic contacts I believe, but no idea what, focus distance? maybe?
http://www.bdimitrov.de/kmp/technology/lens_terms.html
Regards,
John
Regards,
John
It makes no difference whatsoever. I'd choose the one that looked best to my eyes from an aesthetic point of view.
Posted 10/08/2010 - 22:39
I'd take what ever was offered!
I was after an FA 50, but a certain 40mm came along sooo...
Posted 17/08/2010 - 14:38
The FA purportedly has superior electronics, comminucating things such as MTF info to the camera for MTF-program mode and the like. The FA is also much nicer to look at!
Posted 17/08/2010 - 14:53
I've had the F f/1.7 and the FA f/1.4. The F f/1.7 was sharper at every aperture than the FA f/1.4.
I was in two minds about selling the F f/1.7 because it was such a good performer. I eventually sold them both and if I need a 50mm I have the A Series f/1.7 and f/1.4.
The A Series f/1.7 matches the F f/1.7 at most apertures so if you just want sharpness the A series is about £100 cheaper but no AF
Posted 17/08/2010 - 15:02
I think that is to be expected. If you were comparing the F 50mm 1:1.7 to its FA equivelant, I doubt you'd know the difference from the IQ. The FA 50mm 1:1.4 is known to produce softer images than the 1.7 variant, and the 1.7 is also known to be one of the sharpest kit lenses of all time.I've had the F f/1.7 and the FA f/1.4. The F f/1.7 was sharper at every aperture than the FA f/1.4.
You need to compare apples with apples.
Posted 17/08/2010 - 19:44
Out of curiosity what do you actualy mean by softer images? It a phrase often used on the forum and I have never quite understood it.Can you show an example?
Dave
Dave
Posted 17/08/2010 - 19:53
I have the F version and it is a fantastic lens which does communicate MTF data to the body.
If you have older film bodies it would be the only choice but I very much doubt if there is any discernible difference between the two.
Edit:
Just a thought, but isn't it the case that the body is programmed with the MTF data? It doesn't seem likely that Pentax would build lenses containing this info long before a body could use it.
Edit:
Posted 17/08/2010 - 20:11
I think you're correct with other lenses with "A" aperture I think it simply stops down one or two stops, ain't sure though.
Posted 17/08/2010 - 20:27
I can't show an example right now, but if you look at most good portraits, they have a dreamy, creamy look to them.Out of curiosity what do you actualy mean by softer images?
That's softness.
It's a bit like an image being slightly out of focus, but not.
The softness of some lenses, including the FA 50mm 1:1.4, is often used in portrait photography. It helps hide some of the imperfections found in the skin, particularly of older people.
Let's face it, if you had a portrait shot done, you probably wouldn't want to have every pore showing up.
That's softness.
Pentax even made a 'soft' portrait lens, three actually. Check out the three 85mm lenses here.
Posted 17/08/2010 - 20:36
Thanks Pete,
Yet another consideration take in. The learning never ceases....
Posted 28/08/2010 - 18:58
with reference to Algernon,s comment on iq difference between FA f1.7 (sharp) and FA f1.4 (soft). is the same true of the A series. i have the A 50mm 1.7 and was thinking of parting with it for the f1.4 but if the image from each has a different character then perhaps having the two would be better. any thoughts anybody.
Posted 28/08/2010 - 19:30
Never sell a 50mm f/1.7 A series It's sharp on film and digital and has a flatter field than the f/1.4's. The 50mm f/1.4 A is very close to the f/1.7 A for sharpness. From f/1.7 to f/2.8 the f/1.7 lens is slightly sharper. From and including f/4 and above there is nothing to choose between the two. Unless you also do film I can't see any point in buying a f/1.4 if you already have a f/1.7. The viewfinder image is a little bit brighter on the f/1.4with reference to Algernon,s comment on iq difference between FA f1.7 (sharp) and FA f1.4 (soft). is the same true of the A series. i have the A 50mm 1.7 and was thinking of parting with it for the f1.4 but if the image from each has a different character then perhaps having the two would be better. any thoughts anybody.
The 50mm f/1.7 'M' is very close to the 'A' lens, slightly less contrast on film, but missing the A setting on the iris.
For a different bit of character try something like a Helios 58mm f/2, they do vary a lot in build quality though.
Chester,
U.K.
Davex.
My flickr: link
