Extreme Poll
This topic has a poll - login to enter
Posted 11/06/2014 - 08:45
I have an extreme pro only because some one selling it cheap second hand cant say noticed a difference
Posted 11/06/2014 - 11:15
Another unanswerable poll.
I use Integral Ultra Pro 16MB SDHC cards. I've got about 10 of them. Some are class 6 others are class 10. I just looked and the class 10 version says upto 23MB/s
I've never noticed the class 6 version being any slower.
Posted 11/06/2014 - 12:09
I think the Extreme Class 10 80 MB/s was renamed Extreme Plus Class 10 80 MB/s. The Extreme Pro Class 10 95 MB/s is just a little bit faster. To get the extra speed benefit from these cards your camera has to be UHS compatable. The K5 for example is not and the Extreme 45 MB/s would be just as good.
Class 10 means minimum write speed of 10MB/s. The other figure is the read speed which is higher then the write speed, the Extreme Pro Class 10 95 MB/s is quoted as upto 95MB/s read and 90 MB/s write.
Posted 11/06/2014 - 12:39
Can't comment directly on those particular cards but as screwdriver222 says it is as much about the camera you have as it is about the cards.
I use a K-x and have shot over a thousand times fast moving karts or planes..almost entirely on single not continuous shooting mode. I used to use a Fuji class 6 then got a Sandisk Ultra class 10. Shooting on the highest JPEG quality setting my file sizes per image are between 5-6MB. Using the Fuji class 6 I could only take about 3 shots within a 2 second interval before the camera stopped working whilst it saved to the card. Using the Sandisk Ultra class 10..it was very slightly better...or at least I perceived it to be so..I didn't actually time it..it could be wishful thinking ...but about 4 shots within 4-5 seconds before it cut out again. The other variable to consider is the batteries you use. I generally use Ansmann 1.2v NimH 2850mAh..i do wonder whether using Lithium AA might increase the shooting/saving performance.
I should imagine that if using a 20-24MP sensor and saving a file size per image of
12-15MB then you might benefit from a really fast card if shooting sport/ aircraft/ cars etc but most people most of the time probably don't need to pay extra for this level of performance and if you are shooting landscapes then probably a class 6 is perfectly adequate.
Just my thoughts.
Just my thoughts.
Posted 11/06/2014 - 17:18
I've used Sandisk Ultra and Extreme and haven't noticed much difference in camera. Getting images off onto the laptop though is much faster with the quicker cards. I always take the card out of the camera and use the card reader on the laptop, rather than plug the camera into USB.
Posted 11/06/2014 - 17:44
Mine just list as class 10 Extreme 45 mb/s. Never had issues with cards and transfer back to PC not an issue as I put the kettle on or do something else. I always transfer by cable from my K5 to PC.
In camera use the buffer seems efficient enough with a bit of a wait to see previews if I've been going mad with fleeting wildlife. I doubt buying much dearer cards would make any difference that mattered.
I don't do video so stick with 16gb cards.I might review this if i eventually get a K3 or similar.
Posted 16/06/2014 - 08:57
2. Do you use the Pro version? In the real world - do you notice any difference?
The Speed restrictions are in the camera. 2. Do you use the Pro version? In the real world - do you notice any difference?
My K5 with the same card as used in my X-5 is a lot slower when using the cable download than with the X-5.
I suppose you can get some speed advantage with some cards, if you use the latest external download device.
However your computer , depending on its age , also has some speed restrictions.
Just make a cup of tea or coffee. That solves the speed problem.
Regards, Horst
Knaresborough,
North Yorks
I use class 10 cards - most of which are Sandisk Extreme or similar.
Sandisk (and others) now sell multiple versions of class 10 cards. Sandisk for instance sells:
The Plus costs around 20% more than the Extreme and the Pro around 25% more.
I can not see any difference between Extreme and Plus other than the premium price.
Clearly for an additional 25% with the Pro - you are getting a card that is in theory 18.75% faster than the standard Extreme.
Questions:
1. Is there a difference between Extreme and Plus or is this just a nice little earner that the Sandisk marketing team have come up with?
Until convinced otherwise - I can not see any point in paying the extra for these versions. Am I alone in this? - as the poll says - how extreme are you?
Carl
